Author Topic: Auto Gearbox stuck in "Park"  (Read 1757 times)
Jim Durham
  • Durham
« on: 08 December 2010, 12:03:29 »
Started the car up this morning, usual "brakelight check" message, pressed brake pedal, message went off but gearlever still locked in park. Problem with brakelight switch possibly????
Re: Auto Gearbox stuck in "Park"
« Reply #1 on: 08 December 2010, 12:08:05 »
... Problem with brakelight switch possibly????
Very likely, in the mean time, if you lift the gaitor from the gear shift, you'll see a yellow lever which will allow you to by-pass the solenoid.  :y
page 139 http://homepage.ntlworld.com/andrew.reynolds983/Manuals/Omega2002Manual.pdf
« Last Edit: 08 December 2010, 12:10:07 by Andy_B »
djac
  • West Sussex
    • 2001/Y Omega 3.2 Elite
« Reply #2 on: 08 December 2010, 12:32:11 »
Surely not, if the check message is clearing when the brake pedal is pressed?
Can you hear the solenoid click when you press the brake pedal?
« Reply #3 on: 08 December 2010, 12:35:24 »
the brake light switch has two sets of contacts. A new switch cured mine, as it has others here!  :y
Boditza
  • Craiova, Romania
« Reply #4 on: 08 December 2010, 12:36:55 »
a little off topic but i have manual and i still get the  brakelight check on my cid.. why is that??
p.s. check the battery voltage.. just a thought
« Last Edit: 08 December 2010, 12:37:18 by boditza »
djac
  • West Sussex
« Reply #5 on: 08 December 2010, 12:36:57 »
Ah, ok. Nothing is ever simple  :y
« Reply #6 on: 08 December 2010, 12:40:59 »
Cheap bulbs can confuse the brake check module, maybe try more expensive bulbs, and clean up all contacts.  :-/  :-/
Jim Durham
  • Durham
« Reply #7 on: 08 December 2010, 13:05:15 »
Thanks for all that chaps. In the meantime been out and started the car again, no problem this time, must be something intermittent. As long as I know I can disengage manually I'm happy with that.
Boditza
  • Craiova, Romania
« Reply #8 on: 08 December 2010, 13:44:21 »
andy i was talking about this:
it just needs you to press the brake then it disapears.. so what does it do?? and why is it also on manual transmision
djac
  • West Sussex
« Reply #9 on: 08 December 2010, 14:00:18 »
AFAIK it simply checks that the brake light bulbs are working.
Nothing to do with auto or manual.  :y
« Reply #10 on: 08 December 2010, 16:31:31 »
....it just needs you to press the brake then it disapears.. so what does it do?? and why is it also on manual transmision
Sorry, I mis-understood you  ;). As djac says, it just confirms that both brake lights work when you press the brake pedal for the first time.  :y Take a brake light bulb out & see what it does  ;) you should get the same display  ;)
Boditza
  • Craiova, Romania
« Reply #11 on: 08 December 2010, 20:59:44 »
its not mentioned in the manual and i was curious.. besides the previous owner of the car said that by pressing the brake it activates the check system :)
harpersimon
  • Marlow, Bucks
  • Live fast, Die young - leave a good looking corpse
« Reply #12 on: 08 December 2010, 23:11:50 »
until you press the brake pedal, the system cannot check the bulbs - hence it goes off when you press the pedal. Until then its not had a proper circuit back from the bulbs to verify they are ok.
