Author Topic: radio/heated rear window.  (Read 2981 times)
tidla
  • solihull
« on: 07 December 2010, 20:07:20 »
both work fine, but not together.earth connections in boot are ok. should i look at boot amp next or elsewhere?
Re: radio/heated rear window.
« Reply #1 on: 07 December 2010, 20:53:21 »
Good place to start. Have to remove parcel shelf partly to access it
Boditza
  • Craiova, Romania
« Reply #2 on: 09 December 2010, 15:21:12 »
i've just noticed this a few moments ago in my car.. if i tune a radio and it hasn't got a strong signal when i press the heated window button i just get static, but on a verry low volume static. on stations with strong signal i don't have this problem yet there is a small static noise on the bacground with heated window turned on. what is wrong with this?
p.s. its raining outside.. i didn't noticed this when the weather isn't wet :|
p.p.s by interogating google i found out that by haveing the heating lines interupted can do this.. i have 3 heating lines on the rear window that don't work :(
« Last Edit: 09 December 2010, 15:32:07 by boditza »
mrjimbo
  • Oxfordshire
« Reply #3 on: 09 December 2010, 15:33:32 »
I get the same problem on mine aswell, but mines an Estate.
Kneepad
  • West Scotland
« Reply #4 on: 09 December 2010, 15:39:11 »
If I'm not mistaken, some of the Omegas use the heating element as an aerial, so if you have damaged tracks on the element this may well be the problem.
mrjimbo
  • Oxfordshire
« Reply #5 on: 09 December 2010, 15:41:59 »
Not on mine, it has a roof mounted airiel.
Boditza
  • Craiova, Romania
« Reply #6 on: 09 December 2010, 15:42:06 »
i have the damaged tracks but my antena is on the roof.. not in the rear window because mine is also an estate :)
Kaycee
  • Doncaster
« Reply #7 on: 09 December 2010, 16:22:01 »
you can buy conductive from maplims
and i thought ariel was for the phone
There is a tide in the affairs of man if taken at the flood will lead on to greater things
markrl
  • London
« Reply #8 on: 09 December 2010, 16:52:02 »
My understanding is that the aerial on the roof is for fitting a mobile car phone and the heated rear screen does indeed act as an aerial which is why this problem occurs. I have this problem occasionally on a saloon and it does seem worse in damp winter conditions. One possible cause is a poor earth but it can also be caused by interference from a dealer sticker stuck on the back window across the heating element. The sticker can get a bit shrivelled with age and trap moisture between itself and the heating element of the window causing static. Try taking any dealer sticker off the window if its sitting over the track lines and you may get a bit of an improvement. I have to say that using the heated rear window as an aerial is a pretty poor system, a standard traditional aerial works quite a bit better and doesn't require an amplifier.
Boditza
  • Craiova, Romania
« Reply #9 on: 09 December 2010, 17:03:26 »
i am 100% that the antenna on the roof works for all the systems because it got stolen from the car and i had very very poor reception on the radio whenever i got out of the city, bought a new antenna and the radio worked like a charm again untill i started to notice this static :(. on rear window antennas there are some vertical lines too.
p.s. no sticker on mine
« Last Edit: 09 December 2010, 17:03:55 by boditza »
markrl
  • London
« Reply #10 on: 09 December 2010, 17:12:54 »
The stubby aerial on the roof is definately for a car phone. The heated window element is used as the aerial and this problem of static is quite common not just on the Omega but quite a few other cars that use this silly system. Because the heating element can only produce a pretty weak signal an amplifier is used under the parcel shelf and the whole system seems quite prone to interference.
Boditza
  • Craiova, Romania
« Reply #11 on: 09 December 2010, 17:32:53 »
what is the parcel shelf and why do you think the radio went down when the antenna was not present?? anyone who has roof antenna on a caravan can try this and see that without it the radio reception gets pretty bad
« Last Edit: 09 December 2010, 17:33:09 by boditza »
Brikhead
  • West-Mids.
  • Sleeping. Do not disturb.
    • 2003 chitroen Saxo
« Reply #12 on: 09 December 2010, 17:37:57 »
Perhaps the radio uses the rear screen and the roof aerial.
Also I think the aerial signal amp is only used on am or mw, not fm...
Brikhead
  • West-Mids.
« Reply #13 on: 09 December 2010, 17:39:46 »
what is the parcel shelf...
The piece of trim between the rear window and the rear seats, usually refers to saloons only.
Boditza
  • Craiova, Romania
« Reply #14 on: 09 December 2010, 18:16:42 »
so where is the amplifier in estates??
