Author Topic: Problems with Throttle  (Read 1800 times)
ValleysOmega
« on: 09 December 2010, 10:32:46 »
Hi guys, jumped in my 2.2 2002 CDX auto this morning and she fired up but when I press the accelerator nothing happens! I'm wondering whether its a throttle cable or if the battery is not creating enough volts?? Can someone help, Please, I've tried searching various posts, but wondered if someone had come across this before and could guide me to the right...errr....Guide!
Many thanks in advance,
Gav :'(
DaveL
  • Nr. Cupar, Kingdom of Fife
Re: Problems with Throttle
« Reply #1 on: 09 December 2010, 11:16:46 »
Hi,
The 2.2 is a DBW (drive by wire) which unfortunately means it is controlled via the ECU.
I have had a similar problem with my Omega.
If you can have a look at the throttle pedal. There is a connector there, small plug, which some times gets caught by the drivers feet. Check to see if the connection is o.k. Another possability is the connecting plug on the side of your throttle. Could also be a jammed butterfly inside the throttle but my guess would be the plug on the throttle pedal.
Dave.
ValleysOmega
« Reply #2 on: 09 December 2010, 11:21:18 »
Thanks Dave will have a look at that now! ;)
ValleysOmega
« Reply #3 on: 09 December 2010, 11:35:13 »
Just checked and she'll rev a little, but not as she should, seems to me like i've got to clean the throttle body and the butterfly, probably never been done, does this sound about right? >:(
ValleysOmega
« Reply #4 on: 09 December 2010, 13:05:04 »
Just got in it again now, switched her on same problem, would turn over and no throttle control, switched her off then restarted, found I had throttle control!! Very Weird!! ;D
DaveL
« Reply #5 on: 09 December 2010, 13:22:27 »
Go for a throttle clean,using the 'How to', cannot do any harm and may sort your prob. :y
DaveL
ValleysOmega
« Reply #6 on: 09 December 2010, 13:27:02 »
Yeah mate, got to change the front discs and pads this weekend anyway might just clean out the throttle assembly at the same time, ready for her MOT! Thanks for the help! :y
peterm
« Reply #7 on: 09 December 2010, 19:34:46 »
i think this cold is geting to the 2.2  as iv had a problme and today all gone a n driving like new and mine was looking like maf unit but was geting code from all over place
i think ill give the throttel body a nother clen just in case iv got  some crap in ther somwher may be causing my problem
and being to clen can never do it any harm
