Author Topic: 2.2 eco tec fault codes  (Read 1774 times)
peterm
« on: 08 December 2010, 17:59:16 »
ok im back agine to bother you all agine  im geting fault codes
p011o in take temp ect
p1555 throt pos cens a/mass(maf)
cleaned throtell body vacume pipe hole ect as i do every year
clean maf with a good electonic cercuite bord component clener and a gentel blow with air line air box clean and new air filter
reset codes all was well as this was a couple of months back
now geting code p0170 have reset code went for drive was ok but later in day came back on so cleared code and belted life out of old gilr in sports mode only to find was not pulling as fast as she should and fell a bit slugish
now could this me icing of air filter of any thing like this
i now your all going to say problay maf but just wondering
as i suspect the air filter i got from vauxworld was not an oem one as he stated  just a crappy wight box job like his noisy barke linings i got of him as well
oh one other thing iv changed rad and it takes longer for car to warm up on temp gage heater still working as normall
and other day when left ideling  for a time aftera drive was runing at half way then went back to about 80 or just below once i started moving agine just in case this is of help
thanks for any help the wife will be happy as it her car and it means iv not got to get my beloved 150 sri vecy out in cold and ice and no as much fun to drive with out traction
nothing like screing life out of wife and kid by snow drifting lol ;D
« Last Edit: 08 December 2010, 19:49:29 by pmattock »
Re: 2.2 eco tec fault codes
« Reply #1 on: 08 December 2010, 18:10:02 »
Unplug MAF and see if it runs any better...........and never try to clean the MAF sensor with anything..........doesn`t do sod all apart from bugger it up
peterm
« Reply #2 on: 08 December 2010, 18:52:42 »
ok will give it a go wll i get should i get codes from this
also are the pattern maf ok or best stick genuine part as with cam censors
« Last Edit: 08 December 2010, 18:53:26 by pmattock »
« Reply #3 on: 08 December 2010, 18:59:16 »
Geniunie parts for things like MAF & cam sensors :)
peterm
« Reply #4 on: 08 December 2010, 19:52:36 »
righ have found a few simens ones for sale at right price will give it a driv with no maf pluged in to see what happens
cars been a pain this year with springs shocks tyres and rad now this all in a few month of each other as well carnt moan realy had it a time now and fist thing to go rong realy
peterm
« Reply #5 on: 08 December 2010, 21:15:51 »
wife cam in saying light stayed on once she started up
so iv in pluged maf wet for littel drive and felt a lot beter
as has been drinig a bit like i still had the tracktion button on
slugish to pull away ect
and with out maf when like a dream
one qwestion if i plug my code redaer in and not have mad pluged in can i put light out and will it stay out
i now a bit dippy but you just have to ask in case
Kneepad
  • West Scotland
« Reply #6 on: 08 December 2010, 21:21:35 »
No, if you clear the code it will come back. Light will stay on.
peterm
« Reply #7 on: 08 December 2010, 21:24:27 »
worth a try
just wondering if my vect 2.2 has sak maf will have to look
as i can swap em out that will answer qwestion if it has
 am thinking the on on it is not an origanall as iv not seen a part nuber on it ans no makers mars let alone a bar code
may be a cheapo
peterm
« Reply #8 on: 09 December 2010, 19:40:54 »
vecy  maf is not sam shame but woth looking up
but today did restet agine afetr taking for a drive with no contection  and te light has been out all day as iv been poping around a bit and performing well  so may be i had a bad contetion and  unpluging and resetting clened it up a bit
good new is my local vax dealer only wont 95 for a new one
and that not bad as the doggy goit i vaxworl wont 85 and i dont trus themn as far as i can throw em
