Author Topic: New coil pack needed methinks  (Read 3149 times)
« on: 08 December 2010, 15:36:43 »
First there was code 0300, then code 0305 (oil in plug 5 needing new gasket set.) Now we have 0306
I have just spent 2 hours trying to lift the coil pack from 2,4,6 cylinder bank. My blood is everywhere.
I think the coil pack is Donald ducked. Any idea how much for a new one? Can I use a pattern part or second hand part?
Any ideas please.
Re: New coil pack needed methinks
« Reply #1 on: 08 December 2010, 15:45:50 »
A bit to coincidental for my liking TBH.
Two totaly unrelated faults occuring at the same time!
Were both cam cover seal sets replaced at the same time or not and were the breathers cleaned?
« Reply #2 on: 08 December 2010, 16:23:21 »
I have no idea Mark......The gaskets may well be original.....I have just paid £38 for a genuine VX gasket set for cylinders 1,3,5,after finding oil in plug 5.  The  coil pack from 2,4,6...looks like it's been on the way out for some considerable time.....perhaps this cold snap has finally finished it off. :-? :-?
Welung666
« Reply #3 on: 08 December 2010, 16:30:03 »
The 246 bank looks like water damage. Once you have finished doing the cam covers and you've replaced the skuttle run a bead of the black sealant around each wiper spindle and down the seam where the 2 halves of the skuttle come together :y
« Reply #5 on: 08 December 2010, 17:03:28 »
Thanks Welung....
This may well be a stupid question.....but are they £69 each or the pair?.......are they new ...or are they reconditioned?....They make reference to "having been tested".... :y
« Last Edit: 08 December 2010, 17:03:45 by optimist »
« Reply #6 on: 08 December 2010, 17:22:33 »
£69 the pair. Not new, not recon. Taken from a breaker (note the user name)
Welung666
« Reply #7 on: 08 December 2010, 17:30:10 »
Read the about us section near the bottom of the ad, states they are tested, if in doubt, call them ;) :y
« Reply #8 on: 08 December 2010, 18:13:35 »
You can buy a brand new(single) Bosch coil pack for £65......so the breakers want more than 50% of the cost of a brand new one.....for a coil pack that is at least seven years old.....and probably just about to fail....Crazy... :'( :'( :'(
Welung666
« Reply #9 on: 08 December 2010, 18:46:55 »
Have a search on eGay, there is a pair of new ones listed for £125 :y
« Reply #10 on: 08 December 2010, 19:01:04 »
Will do ...thanks :y
peterm
« Reply #11 on: 08 December 2010, 20:34:28 »
try having a serch on goble by part number as well you may find them thers also
scarpies are just pricing them sleve out of a job now days
70 qwid an alet nator  i got a recon fot 90 with 12 monts warenty
50/60 for a rad only 95 new for generic one but still a new rad
may not last as long a gebnuine vau but will last longer tahn used
Brikhead
  • West-Mids.
  • Sleeping. Do not disturb.
    • 2003 chitroen Saxo
« Reply #12 on: 08 December 2010, 20:44:34 »
I wrote that exact name on a package today, the package contained a slightly used Elite A.B.S. pump and E.C.U.
Kneepad
  • West Scotland
« Reply #13 on: 08 December 2010, 20:52:30 »
What you saying Brikhead, someone buying from you then selling on at a profit on theBay ?
« Reply #14 on: 08 December 2010, 21:37:37 »
How much water and condensation was in no 6 plug well?
I have to be honest, that coil pack looks worse than it is, no swelling of the iron evident and no major cracks around the casing.
