Author Topic: Screen wash not working  (Read 1729 times)
willerby
« on: 10 December 2010, 11:07:50 »
No screen wash for front or back. All fuses ok and water not frozen. Anybody know how they are wired or where I can get a wiring diagram from to carry out some tests. Thanks :)
Kneepad
  • West Scotland
Re: Screen wash not working
« Reply #1 on: 10 December 2010, 11:10:21 »
The filter at the base of the pump is very prone to blocking, check this first.    :y
willerby
« Reply #2 on: 10 December 2010, 11:26:21 »
Do you need to remove the pump. I wanted to check that power was getting to the pump first. :)
« Reply #3 on: 10 December 2010, 11:28:50 »
Yep, just lift it out. Then remove the rubber grommet, which is the filter. There will be some water loss.
willerby
« Reply #4 on: 10 December 2010, 11:34:12 »
Does it lift out vertically or is it horizontal towards the engine.
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
« Reply #5 on: 10 December 2010, 11:35:56 »
blocked filter won't stop the pump running though
other rides
  • Online Online
« Reply #6 on: 10 December 2010, 11:48:53 »
It's just one pump for both screens, one direction for front & the other for the rear. Can you hear the pump running when you press the button?
willerby
« Reply #7 on: 10 December 2010, 13:15:56 »
Sorted. Disconnected elec connector and contacts looked slightly corroded. Cleaned it up and now it works. Thanks for the help. :y
Jaymd
« Reply #8 on: 10 December 2010, 19:17:38 »
yea that happend to mine sometimes you need rinse the bottle out because other crap still keeps getting sucked up into the filter it can be a right pain 3 times i cleaned my filter before i relaised i had to wash the bottle out lol
Turk
  • Llanelli, Wales
    • 2.5td, H-D XL1200
« Reply #9 on: 10 December 2010, 20:47:20 »
..er...you are not alone on that one.  :-[ ::)
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
« Reply #10 on: 11 December 2010, 12:55:40 »
And having cleaned it, only fill the bottle through a fine filter. Haven't had a problem with mine in 11 years following this procedure. :y
« Reply #11 on: 11 December 2010, 13:23:20 »
I find using a sensible screenwash mixture stops the nasty 'white sludge' growth
Shackeng
  • Ramsbury
« Reply #12 on: 11 December 2010, 13:29:04 »
^^^^What he said as well. 8-) 8-) 8-)
