Author Topic: hbv fault??  (Read 818 times)
rickmv6
  • moreton  wirral
hbv fault??
« on: 11 December 2010, 18:36:33 »
should the hbv let any water through to the matrix when there is no vacuum. i have checked mine and it lets a tiny bit through so heater doesnt warm up properly. if there should be a vacuum with engine running what do i look for. thanks  in advance.
alank46
  • South Devon
    • 3L Elite Estate 1996
Re: hbv fault??
« Reply #1 on: 11 December 2010, 19:11:50 »
With no vacuum applied the HBV should let ALL the water pass through the heater.  Vacuum applied and NO water should pass to the heater.
Alan
rickmv6
  • moreton  wirral
Re: hbv fault??
« Reply #2 on: 11 December 2010, 19:53:02 »
with no vacuum it wont let any water pass through the hbv does that mean it has been put back together wrong or can the valve go faulty.  if u manually suck the pipe the little valve moved a bit inside but when u stop it springs back but lets a  bit of water through.
been like this since i bought it 2 months ago .
« Last Edit: 11 December 2010, 19:54:53 by rickmv6 »
