Author Topic: shocks  (Read 1825 times)
liamg
  • rochester
shocks
« on: 10 December 2010, 20:24:19 »
i got omega 1999 2.5 elite, failed mot on rear shock, can anyone tell me if i can put standard shocks on or do i have to fit the electronic adjustable one. thanks
amba
  • Medway towns
    • German V6
Re: shocks
« Reply #1 on: 10 December 2010, 20:27:44 »
Standard shocks are fine ,but you will need to disable the air pump as the pipes will be redundant now..either pull the fuse for it or the relay.
Remember the ride will probably be firmer as air shocks give  softer ride with the elite rear springs.
Standard shocks will be a fair bit cheaper as well.
liamg
  • rochester
Re: shocks
« Reply #2 on: 10 December 2010, 20:37:02 »
thanks for your help
Turk
  • Llanelli, Wales
    • 2.5td, H-D XL1200
Re: shocks
« Reply #3 on: 10 December 2010, 20:44:28 »
Which is no bad thing !  :y
Diamond Black Geezer
    • & a silly coupe coming...
Re: shocks
« Reply #4 on: 10 December 2010, 22:06:02 »
On topic, I would love to hear the definitive list of Omega dampers. As far as Im aware the list is something like this - (oofers feel free to modify/add to the list)
-Standard '94-'00
-Elite adjustables - all years the same
-MV6 '00-'03
-Standard '00-'03
Have read on here that dampers on pre-farcelift MV6 are the same as standard, it's only the springs that differ (though always assumed MV6 dampers'd be irmscher, or 'uprated' in some way, myself.)
Also the facelift models had totally re-jigged, uprated suspension. Which, presumably, meant new springs and dampers.
Have also been told that ALL Omega dampers are the same (obviously saloon/estate rears are different) so, frankly, I dont know what to believe! I can easily see the point of Liamg's original post
Answers on a postcard, please  :)
Re: shocks
« Reply #5 on: 10 December 2010, 22:58:47 »
Ooh, now then.
Face lifts...        Pre face lift
Standard.    Gls, cd cdx.        Afaik same as face lift
Elite. Softer with self levelling rear shocks and springs                                                        Same
Mv6 and sport. lowered sports chassis,                                          Standard springs firmer shocks
15mill lower, firmer but still supple.
Further complications, rear depends if estate or saloon for style of shock and spring,
fronts depend on engine, 4 pot, td, v6 for springs?Shocks are same according to trim level.
Is that right? Discuss....
« Last Edit: 10 December 2010, 23:02:48 by chrisgixer »
Re: shocks
« Reply #6 on: 11 December 2010, 04:19:56 »
As above, plus:
F/l V6 Special saloon: Lowered Sport Chassis.
F/l V6 Special estate: Lowered Sport Chassis, with self levelling rear. (which is nice) ::)
Re: shocks
« Reply #7 on: 11 December 2010, 08:34:14 »
Ooh, now then.
Thats how I understand it, but thought front shocks/springs where the same 4pot/V6/TD (except for Mv6/Elite)
Re: shocks
« Reply #8 on: 11 December 2010, 21:50:22 »
Ok. That all sounds clear enough.
But how, then, do we explain the uprated handling of the facelift? I was of the impression all facelifts had uprated suspension? Certainly in my experience 00-on models seem to just 'feel' nicer than pre.
Not disagreeing, just seeing if anyone has an answer...
« Last Edit: 11 December 2010, 21:55:34 by DiamondBlackGeezer »
Re: shocks
« Reply #9 on: 12 December 2010, 03:34:03 »
From tc web site, looks like ac comes into it as well.
Search Results
Search results 37matches found for Steering & Suspension + Road springs, front (set)
Omega      Part Number      Retail Price      Normal Trade      Trade Club
2.0 16v from '94 to '95      90295660      £213.00      £181.05      £128.87
2.0 8v from '94 to '95      90295660      £213.00      £181.05      £128.87
2.5 TD Estate from '96 to '99      90369029      £306.00      £260.38      £203.00
2.5 V6 exc. air con., to '97      90509078      £209.00      £177.65      £126.45
2.5 TD exc. air con., to '97      90509078      £209.00      £177.65      £126.45
3.0 V6 exc. air con., to '97      90509078      £209.00      £177.65      £126.45
2.5 V6 with air con., to '97      90509080      £244.00      £207.79      £148.05
3.0 V6 with air con., to '97      90509080      £244.00      £207.79      £148.05
2.5 TD with air con., to '97      90509080      £244.00      £207.79      £148.05
3.2 V6 with lowered sports chassis, exc. increased payload, from '00      90510279      £184.00      £156.66      £111.47
3.0 V6 with lowered sports chassis, exc. increased payload, from '00      90510279      £184.00      £156.66      £111.47
2.6 V6 with lowered sports chassis, exc. increased payload, from '00      90510279      £184.00      £156.66      £111.47
2.2 DTi with lowered sports chassis, exc. increased payload, from '00      90510279      £184.00      £156.66      £111.47
2.5 V6 with lowered sports chassis, exc. increased payload, from '00      90510279      £184.00      £156.66      £111.47
2.0 16v exc. air con., from '96 to '99      90540869      £247.00      £210.67      £149.85
2.0 8v with air con., from '96 to '99      90540869      £247.00      £210.67      £149.85
2.0 8v exc. air con., from '96 to '99      90540869      £247.00      £210.67      £149.85
2.0 16v with air con., from '96 to '99      90540870      £220.00      £187.00      £133.11
2.0 16v exc. air con., exc. lowered sports chassis, exc. increased payload, from '00      90540870      £220.00      £187.00      £133.11
2.2 16v exc. lowered sports chassis, exc. increased payload, from '00      90540870      £220.00      £187.00      £133.11
3.0 V6 exc. Lowered sports chassis, exc. increased payload, from '00      90541754      £247.00      £210.67      £149.85
2.5 TD with air con., from '98 to '99      90541754      £247.00      £210.67      £149.85
2.2 DTi exc. lowered sports chassis, exc. increased payload, from '00      90541754      £247.00      £210.67      £149.85
3.0 V6 with air con., from '98 to '99      90541754      £247.00      £210.67      £149.85
3.2 V6 exc. Lowered sports chassis, exc. increased payload, from '00      90541754      £247.00      £210.67      £149.85
2.0 DTi exc. lowered sports chassis, exc. increased payload to '00      90541754      £247.00      £210.67      £149.85
2.6 V6 exc. lowered sports chassis, exc. increased payload, from '00      90541754      £247.00      £210.67      £149.85
2.5 V6 with air con., from '98 to '99      90541754      £247.00      £210.67      £149.85
2.5 V6 exc. lowered sports chassis, exc. increased payload, from '00      90541754      £247.00      £210.67      £149.85
2.0 DTi with air con., to '99      90541754      £247.00      £210.67      £149.85
2.5 V6 exc. air con., from '98 to '99      90541897      £null.00      £null.00      £null.00
2.5 TD exc. air con., from '98 to '99      90541897      £null.00      £null.00      £null.00
3.0 V6 exc. air con., from '98 to '99      90541897      £null.00      £null.00      £null.00
2.0 DTi exc. air con., to '99      90541897      £null.00      £null.00      £null.00
2.2 16v with lowered sports chassis, from '00      9193195      £211.00      £179.90      £127.96
2.0 16v with lowered sports chassis, exc. increased payload, from '00      9193195      £211.00      £179.90      £127.96
2.2 DTi exc. lowered sports chassis, form '00
Re: shocks
« Reply #10 on: 12 December 2010, 03:38:50 »
And shocks....
Search Results
Search results 12matches found for Steering & Suspension + Shock absorbers, front (single)
2.0/2.2 exc. lowered sports chassis - LH      72119076      £89.50      £76.11      £56.80
The combination of applications and part numbers listed above for shock absorbers are 'Aftermarket Recommended'. If a Retailer or Trade Customer needs to make a shock absorber related claim on a vehicle still under a New Vehicle Warranty, a Sureguard Warranty or a Network Q Warranty, the correct part number for that specific vehicle must be identified by a Vauxhall Retailer using EPC for the warranty claim to be accepted
2.0/2.2 exc. lowered sports chassis - RH      72119077      £89.50      £76.11      £56.80
2.5/2.6/3.0/3.2 exc. lowered sports chassis - LH      9192249      £76.00      £64.63      £47.83
Diesel exc. lowered sports chassis - LH      9192249      £76.00      £64.63      £47.83
Diesel exc. lowered sports chassis - RH      9192250      £76.00      £64.63      £47.83
2.5/2.6/3.0/3.2 exc. lowered sports chassis - RH      9192250      £76.00      £64.63      £47.83
2.0/2.2 lowered sports chassis - LH      9192289      £76.00      £64.63      £47.83
2.0/2.2 lowered sports chassis - RH      9192290      £76.00      £64.63      £47.83
Diesel lowered sports chassis - LH      9192291      £76.00      £64.63      £47.83
2.5/2.6/3.0/3.2 lowered sports chassis - LH      9192291      £76.00      £64.63      £47.83
2.5/2.6/3.0/3.2 lowered sports chassis - RH      9192292      £76.00      £64.63      £47.83
Diesel lowered sports chassis - RH      9192292      £76.00      £64.63      £47.83
