Pages: 1 [2] 3  All   Go Down
Author Topic: Abs ecu Tc and starting issues  (Read 5006 times)
Re: Abs ecu Tc and starting issues
« Reply #15 on: 04 December 2010, 20:09:10 »
Engine :
"My Naff Code Reader" 100219a - PC based diagnostic tool
Date and time>      04/12/2010. 19:704
Workshop information:
The Omega Man
Selected model>      2001
Control Unit:
KW82 protocol initialized.
ECU ID= AF      90566817
Measuring blocks information:
Identifier      1D
Battery Voltage      13.4 V
Immobiliser Signal      Received
Immobiliser      Active
TPS Signal (Throttle Position Sensor)      0.58 V
Simulated Idle Position      Active
Simulated Full Load Switch      Inactive
Mass Air Flow Sensor      0.80 V
Mass Air Flow Sensor      15 kg/h
Coolant Temperature      0.76 V
Coolant Temperature      103 °C
Intake Air Temperature      3.33 V
Intake Air Temperature      25 °C
Engine Type      6 Cylinder
Transmission Coding      Automatic Transmission
Park/Neutral Switch      P - N  0V
A/C Information Switch (Air Conditioning)      Inactive 0V
A/C Compressor Switch (Air Conditioning)      Inactive 0V
Telltale (Check Light)      Off 12V
Fuel Pump Relay      Active 0V
Spark Angle before TDC (Top Dead Centre)      12 °CA
Ignition Coil Cyl. 1+4 (Cylinder)      Load
Ignition Coil Cyl. 2+5      Load
Ignition Coil Cyl. 3+6 (Cylinder)      Load
Knock Signal      Inactive
Knock Retard      0 °CA
Secondary Air Pump Relay      Inactive 12V
EGR Valve (Exhaust-Gas Recirculation)      Inactive
EGR Position Feedback (Exhaust Gas Recirculation)      0.68 V
Fuel Tank Ventilation Valve      0%
O2 Sensor 1      829 mV
O2 Sensor 2      185 mV
O2 Sensor Loop 1      Closed
O2 Sensor Loop 2      Closed
Air/Fuel Ratio 1      Lean
Air/Fuel Ratio 2      Rich
O2-Loop 1 Integrator      133 Steps
O2-Loop 2 Integrator      133
O2-Loop 1 BLM Idle (Block Learn Map)      76 Steps
O2-Loop 2 BLM Idle (Block Learn Map)      47 Steps
O2-Loop 1 BLM Partial Load (Block Learn Map)      135 Steps
O2-Loop 2 BLM Partial Load(Block Learn Map)      132 Steps
Hall Sensor      Active
Engine Speed Pulse      Inactive
Engine Speed      816 RPM
Idle Air Control      140 Steps
IAC Integrator (Idle Air Control)      128 Steps
IAC Adaptation Slope (Idle Air Control)      150 Steps
IAC Block Learn (Idle Air Control)      127 Steps
Desired Idle Air      13 kg/h
Actual Value Idle Air      13 kg/h
Desired Engine Idle Speed      940 RPM
Injection Pulse      2.9 ms
Engine Load Signal      1.1 ms
TPS Load Signal (Throttle Position Sensor)      0%
Vehicle Speed Pulse      Not Received 12V
Vehicle Speed      0 km/h
Intake Manifold Valve 1      Inactive 12V
Intake Manifold Valve 2      Inactive 12V
Torque Control      Inactive
A/C Cutoff Relay (Air Conditioning)      Inactive 12V
Diagnostic Request      Inactive 5V
« Reply #16 on: 04 December 2010, 20:10:21 »
Gearbox :
Date and time>      04/12/2010. 19:820
The Omega Man
Selected model>      2001      Omega-B      Transmission
Control Unit:
Keyword #1: 6B
Keyword #2: 8F
Normal timing parameter set.
vehicleManufacturerECUHardwareNumber 96018355
systemSupplierECUSoftwareNumber: HX 09 32
systemNameOrEngineType:  GS820 X30XE
CalibrationDate: 01
Identifier: 0103
systemSupplierECUSoftwareVersionNumber: 0008
exhaustRegulationOrTypeApprovalNumber: Not programmed
VehicleManufacturerSpecific: 0260002437
VehicleManufacturerSpecific: 3337635588
VIN: W0L0VBP69Y1175447
RepairShopCodeOrTesterSerialNumber:  Not programmed
ProgrammingDate:  FFFFFFFF
systemSupplierECUHardwareNumber: BOS  0201000002
CalibrationEquipmentSoftwareNumber: 96018085 CK
Emergency Mode      Inactive
Selected Mode      Economy Program
System Voltage      13.5 V
Internal Power Control Final Stage      Active
Brake Light Switch      Inactive 0V
Sport Program Switch      Inactive 12V
Sport Program Indicator      Economy 12V
Winter Program Switch      Inactive 12V
Winter Program Indicator      Econ./Sport 12V
Kickdown Switch      Inactive 12V
Selector Position      -P-
Terminal A Selector Position Switch      Active 12V
Terminal B Selector Position Switch      Inactive 0V
Terminal C Selector Position Switch      Inactive 0V
Terminal G Selector Position Switch      Active 12V
Park/Neutral Signal      P - N  0V
Engine Speed      832 RPM
Coolant Temperature Signal      > 40°C
TPS Load Signal (Throttle Position Sensor)      8%
Pressure Regulator Solenoid Valve      863 mA
Calculated Pressure      4.1 bar
1-2/3-4 Shift Solenoid Valve      Inactive 12V
2-3 Shift Solenoid Valve      Active 0V
Band Apply Solenoid Valve      0%
TCC Solenoid (Torque Converter Clutch)      Inactive 12V
AT Output Speed (Automatic Transmission)      0 RPM
AT Oil Temperature (Automatic Transmission)      89 °C
AT Oil Temperature (Automatic Transmission)      0.82 V
Torque Control Signal      Inactive
Desired Torque Control      0%
Actual Gear      -1-
Transmission Ratio      9%
Ignition / Injection Cutoff      85%
Malfunction Indication      Inactive 12V
The Omega Man
"My Naff Code Reader" - KW2000 Communication Window> 2001|Omega-B|Transmission|AR 25/35
Keyword #1: 6B
Keyword #2: 8F
CalibrationDate: 01
Identifier: 0103
Total number of fault codes: 2
P1844 - Ignition/Injection Cutoff Circuit High Input
 (05) - Not present
P1844 - Ignition/Injection Cutoff Circuit Incorrect Signal
 (08) - Not present
« Reply #17 on: 04 December 2010, 20:11:27 »
ABS :
Stationary snapshot, but live data taken on a drive and all sensors always within 1kph of each other
Date and time>      04/12/2010. 19:1037
The Omega Man
Selected model>      2001      Omega-B      Chassis
Control Unit:
Keyword #1: 6B
Keyword #2: 8F
vehicleManufacturerECUHardwareNumber Not programmed
Identifier: 0000
systemNameOrEngineType:  Not programmed
ECUInstallationDate: 00
systemSupplierECUHardwareNumber: 0000000000
systemSupplierECUSoftwareNumber: 024578
Battery Voltage      13.27 V
FL Wheel Speed (Front Left)      0 km/h
FR Wheel Speed (Front Right)      0 km/h
RL Wheel Speed (Rear Left)      0 km/h
RR Wheel Speed (Rear Right)      0 km/h
Valve Relay Command      Active
Valve Relay Feedback      Active
Return Pump Relay Command      Inactive
Return Pump Feedback      Inactive
FL ABS Valves Command (Front Left)      Normal Braking
FL ABS Valves Feedback (Front Left)      Normal Braking
FR ABS Valves Command (Front Right)      Normal Braking
FR ABS Valves Feedback (Front Right)      Normal Braking
RL ABS Valves Command (Rear Left)      Normal Braking
RL ABS Valves Feedback (Rear Left)      Normal Braking
RR ABS Valves Command (Rear Right)      Normal Braking
RR ABS Valves Feedback (Rear Right)      Normal Braking
« Last Edit: 04 December 2010, 20:13:34 by jimbob »
« Reply #18 on: 04 December 2010, 20:15:59 »
Ohhh, and "My Naff Code Reader" can normally program varient coding...
but it appears it can only change a programmed ecu...
This control unit is only partially programmed!
Before you can use this control unit, a procedure
called SPS programming must be done.
This means, that a so called calibration file will be downloaded to the ECU.
This calibaration file contains important settings, and parameters.
"My Naff Code Reader" is currently unable to do this kind of programming.
For more information, please look at your user's guide.
« Reply #19 on: 04 December 2010, 20:18:47 »
OK, looks like at least we know what the issue is, and it need hooking up to a Tech2.  Thanks Jimbob :y
I didn't want Rossi123 to travel if it wasn't something we could sort with one trip...
« Reply #20 on: 04 December 2010, 20:19:48 »
Given previous experience with "My Naff Code Reader"s programming capability, I'm not sure I would trust it for this anyway...
« Reply #21 on: 04 December 2010, 20:22:20 »
Should have said, we were met by that message as soon as "My Naff Code Reader" started communication with the ECU....didnt need to try programming.
rossi123
  • St Helens Lancashire
« Reply #22 on: 05 December 2010, 00:05:54 »
Thanks for letting pop across there on a cold saturday evening your a star, so for the next job it looks like a trip to see the boy and get it sorted and then I can get the other jobs sorted thanks again for your help jimbob :)
« Reply #23 on: 05 December 2010, 10:11:12 »
No worries, glad we got to the bottom of it
« Reply #24 on: 11 December 2010, 15:55:30 »
I've just seen this car, and it looks like the ECU has is either the wrong one (potentially possible it got mixed up at the repairers), or has been corrupted.
Sadly, its not something Tech2 can deal with - as it cannot even read the partnumber, it cannot do anything, as it doesn't know what ECU it is.
« Reply #25 on: 11 December 2010, 16:53:19 »
Thats disapointing, guess its back to the repairers now to see what they have to say, or just call your losses and obtain another from a breaker.
rossi123
« Reply #26 on: 11 December 2010, 17:26:03 »
Just been thinking about it and I'm goin to look into getting another one from a breaker either by posting on here or through other avenues and see what comes of that.
« Reply #27 on: 11 December 2010, 22:03:47 »
as you havent the posts, any wanted ad in the test zone will be moved for you  :y
rossi123
« Reply #28 on: 11 December 2010, 23:56:15 »
Cheers sir your a good un
« Reply #29 on: 12 December 2010, 09:52:47 »
The more I think about this, I'm wondering if the repair wasn't as good as it could be...
Obviously the processor is running to be able to respond to diagnostics, but its as if it cannot read part of its eprom...  ...wonder if power is not getting to entire board.
Yes, very disappointing, I don't like failure, esp as rossi123 isn't exactly just around the corner  :-[
Pages: 1 [2] 3  All   Go Up
