Author Topic: Vibration at 80+  (Read 1784 times)
alfie
  • Gwent
    • Mondeo Ghia estate tdci
Vibration at 80+
« on: 09 December 2010, 19:37:45 »
Not really worried about it at the moment,(to cold to work on car in this weather) but every time that I accidently exceed the speed limit and head into the 80s a vibration starts,Steering is unaffected,seems to be prop shalf?, why would it suddenly appear.
Any other ideas,please.
markspark
  • Bolton
Re: Vibration at 80+
« Reply #1 on: 09 December 2010, 19:42:07 »
could be as simple as a wheel out of balance or a warped tyre, does the steering wheel shake or the car shake ect
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
« Reply #2 on: 09 December 2010, 20:08:34 »
An old tyre man i know once told me, "Any Shaking under 60 front wheels, after 60 rear wheels need balancing or tyre defect." Pretty good advise I found  :y
« Reply #3 on: 09 December 2010, 20:12:54 »
[/highlight]
Have to agree, that's exactly what it was with mine, rear tyre defect. :y
duggs
  • Felixstowe
    • BMW 3.0 Sport
« Reply #4 on: 09 December 2010, 21:02:01 »
Wow....Timely advice...I have the same problem...but it kicks in at about 105    SO...I ain't too bothered at the moment.....not till I set out for the autobahns ?
Will get the rear wheels checked at some point.
Thk you.
« Reply #5 on: 09 December 2010, 21:04:43 »
Thk you.
Gawd only knows how you've lived to be a 104 if you drive like that!  ;D ;D ;D ;)
alfie
  • Gwent
« Reply #6 on: 09 December 2010, 21:24:10 »
Thanks for your inputs,I'll get the wheels balanced as soon as I can,hope that will sort it.
« Reply #7 on: 09 December 2010, 23:42:06 »
if possible, try and find somewhere with a far more accurate 5 stud balancer, as oposed to the more common cone balancer.
SP_3.2
  • Leicester
    • drives A6 allroad 3.0tdi
« Reply #8 on: 10 December 2010, 00:55:43 »
Very ture..had the same problem a few months ago. After a vist to WIM and having the 2 back wheels done on there 5 stud balancer and good as gold now all the way up to *** :y :y.
Pitchfork
  • Tadley (near Basingrad)
  • Barndances & Morris
« Reply #9 on: 10 December 2010, 09:03:04 »
Had a similar problem until a rear tyre exploded at 75mph on the M40
Suggest you get cause identified & rectified PDQ!
PxMetro
  • Stamford
  • Maryland Cookies are brilliant for dunking
    • 3.2 MV6 Estate
« Reply #10 on: 10 December 2010, 21:51:11 »
I agree. For your own sake get the tyres checked out ASAP. Might also be Shocks, or Prop Shaft. Is it a high or low frequency vibration?
Grrrrrr
  • Buckinghamshire
    • Jaguar. WTF have I done?
« Reply #11 on: 12 December 2010, 20:29:50 »
Might even be the rim is distorted if you've walloped a pothole.
Work is the curse of the drinking classes (Oscar Wilde)
