Author Topic: missfiring  (Read 1185 times)
Jaymd
missfiring
« on: 12 December 2010, 15:32:34 »
hey guys again my engine is playing up i thought it was the injector rail but it dosent seem to be the problem. the car is missfiring for some reason any help or tips that i can check??
Re: missfiring
« Reply #1 on: 12 December 2010, 15:38:44 »
Have you had it read for codes :question
vauxhallvauxhall
Re: missfiring
« Reply #2 on: 12 December 2010, 15:45:20 »
more than once I have fitted new plugs and found them to be faulty after 1000 miles  they seem to have bad batches
Jaymd
Re: missfiring
« Reply #3 on: 12 December 2010, 17:28:45 »
thanks guys no havent had the faults read and how do i check if its the plugs?
Re: missfiring
« Reply #4 on: 12 December 2010, 17:46:53 »
Whip the black "Ecotec" cover (you may have to unplug the coilpack connector at the back of it). Unbolt the coilpack (2 x torx), inspect pack for damage/corrosion and check for oil in the plugwells. Ideally you could do with codes reading. Whereabouts are you located.
Jaymd
Re: missfiring
« Reply #5 on: 13 December 2010, 20:47:48 »
i am located in margate kent :)
Re: missfiring
« Reply #6 on: 13 December 2010, 21:16:32 »
So you`ve answered as to where you`re located. have you done what I suggested in my prevous post :)
