Author Topic: Crankshaft sensor  (Read 960 times)
megaomega123
Crankshaft sensor
« on: 15 December 2010, 16:18:58 »
Can someone describe the symptoms of the crankshaft sensor failing.
The main point I need clarifying is, does the engine turn over or is there a big fat nothing?
« Last Edit: 15 December 2010, 16:19:11 by phate321 »
Welung666
Re: Crankshaft sensor
« Reply #1 on: 15 December 2010, 16:32:30 »
The engine will turn over but it won't receive the signal to fire the plugs so won't start.
megaomega123
« Reply #2 on: 15 December 2010, 16:38:26 »
Ok thanks. So that being the case, leads to my next question.
I left work and the car stalled and would not start for 10 minutes. No turning over, no clicking, nothing. All electrics were good. Not done it since. Any ideas?
vauxfan2k
  • Western Isles
« Reply #3 on: 15 December 2010, 18:26:11 »
thats not a crank sensor symptom, sounds like a bad earth, check all the engine bay earths, and the battery connections are tight, also check connections at back of starter.
could also be a solenoid problem on the starter
« Last Edit: 15 December 2010, 18:26:53 by Vauxfan2k »
