Author Topic: fld/vision  (Read 1347 times)
hoj
  • BURY
fld/vision
« on: 18 December 2010, 18:20:14 »
think its been mentiond before but when the display comes up with headlight low fld/vision what is it exactly please.
Cheers all.
3.2 Elite in Oyster
Re: fld/vision
« Reply #1 on: 18 December 2010, 18:29:14 »
Cheers all.
just a few times  ;) ;) It could be a fault with any or all of ....... level sensors on front & rear nearside suspension, or level motors in either or both headlights. I could just simply the level arm has come off the fns sensor though.  :y
hotel21
  • The Kingdom of Fife
Re: fld/vision
« Reply #2 on: 18 December 2010, 18:32:41 »
Snow or slush buildup on the suspension arms has popped the actuating rod off.  Nearside front and rear arms.....
hoj
  • BURY
Re: fld/vision
« Reply #3 on: 18 December 2010, 19:00:23 »
Thanks - If it is a sensor will it be OK to leave it a while will it come off or will it just hang there - dont fancy gettin underneath in this weather :)
3.2 Elite in Oyster
alexandjen
  • Sittingbourne, Kent
  • The Silver Surfer
Re: fld/vision
« Reply #4 on: 18 December 2010, 19:11:16 »
Item 13 in the diagram on this thread, http://www.omegaowners.com/forum/YaBB.pl?num=1237989198, has probably popped off - if it decides to do the same at both ends then you've lost it
Trade club card holder
Code scanner available
Re: fld/vision
« Reply #5 on: 18 December 2010, 19:19:44 »
you don't need to fully get under the car, if you put a full lock on you should be able to reach around the wheel.
