Author Topic: Missfire  (Read 1705 times)
trem
Missfire
« on: 17 December 2010, 13:01:50 »
afternoon to all, on my way to work this morning (11am) once the car had warmed slightly it started missfiring,  i think its running on 5 cylinders maybe less.  I have read on this forum bout leaky rocker cover gaskets and couple other things.
It a 2000 (V) 2.5 v6 gls auto
My question is wat is the most common cause of a misfire on these engines,
i haven't had chance to have a proper look yet but i can a little oil on the exhaust manifold on passenger side so guessin its got oil in one of the plug wells.
Thank you all in advance
skyblue
  • Bracknell
Re: Missfire
« Reply #1 on: 17 December 2010, 13:07:54 »
I would hazard a guess this is where your problem is.
trem
Re: Missfire
« Reply #2 on: 17 December 2010, 13:11:47 »
i was kinda hopin thats what it is, coz i can do a temp fix for now.  i dont know when mine were last changed as i have only had the car a couple months, but it only has 76K on the clock i thought they would of lasted longer than that
omegod
  • liverpool
    • 2017 Seat Ateca
Re: Missfire
« Reply #3 on: 17 December 2010, 13:24:01 »
Rocker covers
Plugs
Leads
DIS pack
This is the general order of play for tracking down a missfire, Good luck matey!!
djac
  • West Sussex
    • 2001/Y Omega 3.2 Elite
Re: Missfire
« Reply #4 on: 17 December 2010, 13:30:43 »
It's not so much that the r/c gaskets themselves fail, it's more that the engine breather system blocks up which then pressurises the engine causing oil to be forced past the r/c gaskets.
So simply cleaning the breathers would go some way to alleviating the flow of oil, but the gaskets will still need to be shanged at some point.  :y
trem
Re: Missfire
« Reply #5 on: 17 December 2010, 15:30:21 »
rite just been out on my break to have a quick look, still not firin on all cyls.  But checked water bottle again and its empty, i changed the water and antifreeze 3 weeks ago and up until tuesday this week the bottle was at the correct level.  i have the usual mayo on oil filler cap and on top of dipstick neck.
how do i go bout cleaning the breathers and how do i get to the plugs, it looks like a right c * * t
« Last Edit: 17 December 2010, 15:31:35 by trem »
skyblue
  • Bracknell
Re: Missfire
« Reply #6 on: 17 December 2010, 16:05:53 »
I would be more worried about the lose of water and would try and fix that first as it sounds to me ( Im no expert either ) that your HBV is leaking onto your dis pack hence why you are getting a misfire,,,,,, Im sure a more knowledgeable one will be aslong soon tho
Kneepad
  • West Scotland
Re: Missfire
« Reply #7 on: 17 December 2010, 22:28:43 »
Clean your breathers following this guide:
http://www.omegaowners.com/forum/YaBB.pl?num=1285583967
                                     ;) :y
trem
Re: Missfire
« Reply #8 on: 18 December 2010, 16:44:15 »
Welung666
Re: Missfire
« Reply #9 on: 18 December 2010, 16:47:50 »
;) :y
This one will though :y
trem
Re: Missfire
« Reply #10 on: 19 December 2010, 20:11:48 »
rite lads after 2days of investigation and swearin, i can now take intake manifold off with eyes closed.
i have checked then changed the plugs,  checked and changed the leads and have come to the conclusion that its the coil pack.  so where is best place (by best i mean cheapest and fastest) to get one from.  or if any members have one for sale near or around newcastle area that i can collect tomorrow.
the one i am after is off 2.5 v6 petrol, its all six leads on one block
