Author Topic: Help with fault codes  (Read 3124 times)
charlie
  • sunderland
« on: 19 December 2010, 20:34:44 »
THis is for an 2.2dti,
p1694-(4) glow time tell tale circuit open-not present
p1690-(4)mal indication lamp(mil)circuit open-not p1125-(5)critical system malfuction(2)
p0105-(1)boost pressure sensor circuit high input np
P1635-(a) glow device circuit general error not present
all help most welcome cheers charlie
« Last Edit: 20 December 2010, 12:38:32 by charlie »
geoffr70
  • Sunderland
  • Boobies
    • F/L 3.0 Elite, 3.0 MV6
Re: Help with fault codes
« Reply #1 on: 19 December 2010, 20:37:23 »
Hi Charlie, this is now in the maint. section. I don't know if it's of any use to you?
http://www.omegaowners.com/forum/YaBB.pl?num=1205270870
TC and BnQ Trade holder.
« Reply #2 on: 19 December 2010, 20:37:56 »
p1694-(4)
p1690-(4)
p1125-(5)
p0105-(1)
P1635-(a)
maintenance section  ;)
http://www.omegaowners.com/forum/YaBB.pl?num=1197277611
charlie
  • sunderland
« Reply #3 on: 19 December 2010, 20:52:04 »
Ive had a look in the mantanice section,there seems to be different faults with the same codes,Im at a bit of a loss with understanding this ::) ::) ::)
« Reply #4 on: 19 December 2010, 21:05:51 »
Oops! I referred you to a petrol engine codes.  :D
you want these .....
« Last Edit: 19 December 2010, 21:07:46 by Andy_B »
fergy
  • Hereford
  • 2001 CDX 2.2dti Estate
« Reply #5 on: 20 December 2010, 21:20:31 »
Hi
Re 2.2 Dti codes
 I believe that this means the glow plug indicator bulb in the dash has blown or other wiring problem, BUT it is shown as NOT  PRESENT so appears to be something that has happened in the past and been fixed.
Is the  general indication that one or more glow plugs or wiring have failed. Again it is  NOT PRESENT so is historic.
 Suggest having noted the codes, you clear them then re read them before  taking too much corrective action.
 Can't help you with the others Sorry.
charlie
  • sunderland
« Reply #6 on: 20 December 2010, 21:42:53 »
Cheers fergie,I wonder if these have anything to do with the little heater being disconnected(the one under the bumper)theres a job for tomorrow.charlie ::)
fergy
  • Hereford
« Reply #7 on: 21 December 2010, 11:16:10 »
Hi Charlie
Do you reckon that the P1690 code is telling you that the MIL ( Malfunction indication Light) has a problem? If so, it sounds as if you have had a couple of bulbs busted behind the dash or some associated wiring problems. I would still reset then see what it comes up with first though.
Best of luck
 Fergi
