Author Topic: Burst water pipe  (Read 2023 times)
Martin_1962
Burst water pipe
« on: 20 December 2010, 18:44:36 »
Was back of engine, by HBV
Had to run another 2 minutes at idle afterwards, did dump 2l of water and 3l of antifreeze in to do the short home bit.
Is it likely to have damaged anything?
Water was in block but not completely in heads.
No nasty noises, no nasty smells cam cover area was not over hot
« Last Edit: 20 December 2010, 18:44:50 by Martin_1962 »
freecall666
  • looking over your shoulder
    • 2.0l sweat tank on wheels
Re: Burst water pipe
« Reply #1 on: 20 December 2010, 18:46:23 »
would keep engine warm if its leaked then the cold from to night could do some damage...
Solar charger fitted.
If not Broke dont fix it..
« Reply #2 on: 20 December 2010, 18:55:54 »
Probably ok - only way to tell is fix leak and refill and try - good luck  :y
Martin_1962
« Reply #3 on: 20 December 2010, 19:47:09 »
Was an LPG T piece got an ally one to fit tomorrow :o :o :( :(
« Reply #4 on: 20 December 2010, 20:16:29 »
Bad luck Martin! :(
It sounds like you got away with it though :y Did the temp. gauge get into the red at all ?
Martin_1962
« Reply #5 on: 20 December 2010, 20:58:28 »
Bad luck Martin! :(
Almost
I reckon this has been my slow water leak as well!
« Reply #6 on: 20 December 2010, 22:14:17 »
Was your antifreeze mix wrong Martin?
If its 50:50 that gives protect down to silly low temps way beyond what we get.
Martin_1962
« Reply #7 on: 21 December 2010, 00:17:04 »
LPG T Piece exploded - got a spare to fit, was near boiling
« Reply #8 on: 21 December 2010, 09:57:13 »
T-Piece?
I thought the standard approach was to place the evaporator in series of the bypass valve?
Martin_1962
« Reply #9 on: 21 December 2010, 11:45:44 »
T-Piece?
And who converted theirs first on the forum and used T Pieces to put thier evaporator in parallel with the heater.
« Reply #10 on: 21 December 2010, 12:22:15 »
T-Piece?
Time to put it right then  ;D
Martin_1962
« Reply #11 on: 21 December 2010, 14:52:59 »
T-Piece?
Why 4.5 years and it runs OK.
I would need a new HBV pipe and the heater matrix out pipe
« Reply #12 on: 21 December 2010, 16:27:23 »
Because your evaporator will get a MUCH better hot water flow and work better, might switch to gas earlier more reliably to
« Reply #13 on: 21 December 2010, 18:49:15 »
Clips not overtightened?
« Reply #14 on: 21 December 2010, 18:56:02 »
Not one of Teilo's T pieces as provided by yours truly? If so, glad I've never fitted one. ;)
Worth considering re-plumbing it, as said. Another advantage is that it reduces the number of jubilee clip connections that could fail. ;)
