Author Topic: 2.2 rocker cover  (Read 1259 times)
griff2494
  • fallingbostal,germany
2.2 rocker cover
« on: 21 December 2010, 12:24:18 »
hi there
does the 2.2 rocker cover come apart?
i need to clean it out as have mayo ,ive had a cotton bud in the breather holes but i want to get right in there
any ideas?
Re: 2.2 rocker cover
« Reply #1 on: 21 December 2010, 12:34:54 »
bolts on top, and cover will just come off (after you removed the coil pack) Is the cam cover leaking?
Check the maintenance guide section for details on cleaning breathers and throttle body, blockage point on 2.2 is small pipe from drivers side of cover to the throttle body. Don't bother cleaning it if its blocked, they are about 80p from Vauxhall!
Abiton
« Reply #2 on: 21 December 2010, 12:51:27 »
I have read on here about someone disassembling the two parts that make up the cover, but I think it takes some minor destruction to do so.  Probably not worth the risk.
« Reply #3 on: 21 December 2010, 21:25:53 »
Eh? The plastic cam cover is one solid piece
Abiton
« Reply #4 on: 22 December 2010, 07:56:23 »
I beg to differ.
Have a look at your picture:
If you look closely, you'll see that from the block breather entry point, round to the two breather outlets in the opposite corner, there's like a 'false ceiling'/'inner cover' bit (semi-circle ending to it).  I'd imagine this is to keep the worst of the condensed mayo/water away from your cams, whose lubrication is rather critical.
I'm sure that someone on here posted a piccy of the two bits separated. Maybe a couple of years ago or more.
I offer you the challenge of finding said picture(s) Tunnie. :)
MartinP
  • Dudley
    • BMW 320D
« Reply #5 on: 22 December 2010, 19:52:45 »
The cover is made of 2 or 3 components glued? together. when I did mine a destroyed the inner part to see how bad it was, then had to buy a second hand one and clean it as best I could before refittting.
Martin
« Last Edit: 22 December 2010, 19:53:28 by issunaz »
