Author Topic: oil leak on my 2.6 v6 cdx  (Read 1254 times)
stevejo
  • manchester
« on: 28 December 2010, 19:59:25 »
hi guys,just got a 2.6 v6 cdx 2002 model,it has a oil leak not to sure were from,but looks like bottom end of engine,seems like theres a bit of oil thats gathered on the ledge at bottom of engine bay behind the rad housing area.And also the dash display lights are only working at one side any advice greatly recieved,cheers steve
Welung666
Re: oil leak on my 2.6 v6 cdx
« Reply #1 on: 28 December 2010, 20:10:05 »
Oil leak is most likely the cam cover, strange as that may sound. Check the shiny machined face right on the outer edge (both sides) right behind the top of the cam bent cover. Unluck Mark MV6 had oil collecting in the same place as you and it turned out to be the cam covers :y
Dash just needs a few new bulbs, check the index in the maintenance guides :y
stevejo
  • manchester
« Reply #2 on: 28 December 2010, 20:20:12 »
cheers mate,is this an easy fix then and how do i do this,cheers
Welung666
« Reply #3 on: 28 December 2010, 20:54:51 »
If it turns out it is the cam covers then they will need replacing with genuine Vx cam covers using the correct black sealant. Easy enough job if you are comfortable with spanners. Have a look in the index in the maintenance guides for the cam cover seals change HowTo and the how to clean the breathers HowTo :y
stevejo
  • manchester
« Reply #4 on: 28 December 2010, 22:20:24 »
cheers pal,will be getting it checked and fixed asap,dash display seems to be all lit up now (after a swift tap or two)
Welung666
« Reply #5 on: 29 December 2010, 01:30:23 »
I have a taillight like that ;D ;D
duggs
  • Felixstowe
    • BMW 3.0 Sport
« Reply #6 on: 29 December 2010, 01:33:02 »
Strange !   I have a wife like that...South African, they need several taps to get them working trust me and then several more to get them to shut up ! :o :o
FORTUNATELY she doesn't generally read this forum but if I don't appear back within a few days assume, mistakenly, that she did !!  Tis been a while since I tasted hospital food.  ::) :-X ::)
« Last Edit: 29 December 2010, 01:36:00 by duggs »
Welung666
« Reply #7 on: 29 December 2010, 01:35:52 »
;D ;D ;D There are laws somewhere to do with the thickness of your thumb ;) :P
stevejo
  • manchester
« Reply #8 on: 29 December 2010, 14:58:05 »
found the problem of oil leak,its the oil pressure switch
