Author Topic: anyone making tubular manifolds for v6 ?  (Read 2487 times)
paulgsi
« on: 26 December 2010, 00:13:37 »
any companys selling tubular manifolds for the v6 in an omega ? cant seem to find anyone selling them
V6Vec
  • Central Scotland
Re: anyone making tubular manifolds for v6 ?
« Reply #1 on: 26 December 2010, 01:17:58 »
There's a guy over on VVOC trying to get a group buy organised for vec v6 tubulars.  You could ask him about the possibility of getting an omega one off the ground.  Would imagine the jigs etc will be easier for an omega set-up.
http://www.vvoc.com/forum/showthread.php?t=344062
« Last Edit: 26 December 2010, 01:20:22 by V6Vec »
« Reply #2 on: 26 December 2010, 01:30:21 »
Tried Courtney? As mentioned in the Saab thread?
paulgsi
« Reply #3 on: 26 December 2010, 12:24:52 »
anyone on here running them on there car ,ill send em an email and see cheers
V6Vec
  • Central Scotland
« Reply #4 on: 26 December 2010, 12:50:08 »
If you want to go to Courtenay be prepared to lube up and bend over.
MartinP
  • Dudley
    • BMW 320D
« Reply #5 on: 26 December 2010, 23:08:57 »
I've got a set of 12mm mild steel flanges to mock up some short pipes to fire up the 3.0 in the kit car, but need to find a magician to build a system local to me.
Martin
msb1973
  • burton on trent
« Reply #6 on: 27 December 2010, 15:35:33 »
Martin
My local custom exhaust guy would/should be able to sort that for you :y
V6 CDX-er
  • Sheffield
« Reply #7 on: 27 December 2010, 16:18:52 »
Martin
Or failing that, RT Racing in Sheffield.
Their metalwork guy, (Pete), is a true craftsman  :)
MartinP
  • Dudley
    • BMW 320D
« Reply #8 on: 28 December 2010, 19:05:39 »
Thanks for the suggestions, I will keep them in mind.
I didn't want to tow/trailer it too far, but will not rule it out to to get the job done properly.  :y
Martin
Martin_1962
« Reply #9 on: 29 December 2010, 17:25:48 »
ABS were planning on doing some.
Main answer now is use the pressed steel facelift manifolds
MartinP
  • Dudley
    • BMW 320D
« Reply #10 on: 29 December 2010, 22:16:35 »
What do they look like?
I have to have single pipes coming off theflange to exit the side panel.
If the pressed steel manifold is just a replica of the cast one the first pipe conection will be somewhere near my toes in the driver & passenger footwells  ::)
Martin
