Author Topic: Knock sensor connector?  (Read 958 times)
omegod
  • liverpool
    • 2017 Seat Ateca
« on: 30 December 2010, 12:25:12 »
Anyone point me in the direction of the drivers side knock sensor plugs in,i.e where it joins the loom? Need to check mine as EML is on and dont fancy scrabbling about under the car
Welung666
Re: Knock sensor connector?
« Reply #1 on: 30 December 2010, 12:36:21 »
It's the plug clipped to the cable tray on the cam belt cover, the wire runs down behind the aux belt tensioner. Has the aux belt tensioner been off recently? If so you may have trapped the wire behind it when re-fitting :y
omegod
  • liverpool
    • 2017 Seat Ateca
« Reply #2 on: 30 December 2010, 12:42:11 »
Cheers Lee, Aux has not been off but I basically ripped the engine bay apart sorting a misfire out, DIs etc so may have tugged the wire. :y
Welung666
« Reply #3 on: 30 December 2010, 12:45:00 »
The knock sensors are pretty much bullet proof, you'll only get a fault if the wiring or plug is damaged. Is the code definately bank 1 knock sensor?
