Author Topic: AR 35 auto gearbox stucked at P state when cold  (Read 1104 times)
Peter13
  • Budapest, Hungary
    • '98 3.0 MV6 Estate LPG
« on: 31 December 2010, 10:45:54 »
Hi!
I have read in several threads that it is usual to these gearboxes to stick in 1st gear for a while when it is cold.
Mine is different. It simply does not let me to release from P mode after some days of parking when it is really cold (below -5 degrees centigrade). If I try to release, I hear a relay switching from the dash, but I can not pull up the "trigger" on the rod. After about 1 minute it let me release it and everything goes normal.
The gearbox has had completely renewed in September. It has v5 software. Any ideas?
thanks!
Welung666
Re: AR 35 auto gearbox stucked at P state when cold
« Reply #1 on: 31 December 2010, 10:54:36 »
Pop the leather gaitor up from around the gear selector and check the yellow lever is moving freely. A spot of lube may help :y
« Reply #2 on: 31 December 2010, 12:06:33 »
...... Any ideas?
thanks!
There's lock mechanism that prevents you from moving the gear selector from Park unless you have your foot on the brake, pressing the brake activates a solenoid to disengage the lock. Either ther brake switch is faulty (probably not in this case cos you can hear a relay switching) or the solenoid is faulty or can't move the lock.
The yellow lever that Welung is describing is the manual over ride for the solenoid/lock.   :y
hoofing it
« Reply #3 on: 31 December 2010, 13:06:54 »
As Andy says but also try pressing the brake pedal several times whilst pulling the realese on the selector.
Mine sticks somtimes as you said you here it clicking. :y
« Last Edit: 31 December 2010, 13:07:30 by hoof »
Peter13
  • Budapest, Hungary
« Reply #4 on: 31 December 2010, 14:21:31 »
Thanks for the responses guys!
So it really has not anything to do with the tempreture?
Anyway, I tried the break pedal, no success. Only the time to wait helps. I don't think I would start to fix it, cos normally I am unable to reproduce it, but at least I know where to search it when it gets worse...
Is that possible that the solenoid is freezed when it does this?
Thanks!
« Last Edit: 31 December 2010, 14:26:54 by kisp113 »
