Author Topic: Glow plugs  (Read 2073 times)
stoxman
Glow plugs
« on: 31 December 2010, 16:30:47 »
Hi all,
Bit of a basic this one but I want to change the glow plugs on my 2.2DTI and I cant get the connectors off. They look like plug caps and I can rotate them, so I just pulled and have pulled the top off one of the plastic caps. This makes me think they dont just pull off and I need one of you to confirm that this is how you do it or put me right on removing them.
Thanks in advance
Stoxman
Welung666
Re: Glow plugs
« Reply #1 on: 31 December 2010, 16:33:05 »
On the 6 cylinder engines they have a small nut (8mm) to hold the cable on and then a 12mm deep socket to remove the plug itself.
Re: Glow plugs
« Reply #2 on: 31 December 2010, 16:34:02 »
and a diseasal Astra is the same idea.
stoxman
Re: Glow plugs
« Reply #3 on: 31 December 2010, 16:35:44 »
Mine is a 4 pot and I cant get at any nuts, if there are any until I can get the plug cap looking thing off.
Welung666
Re: Glow plugs
« Reply #4 on: 31 December 2010, 16:37:06 »
Can you take a pic?
Re: Glow plugs
« Reply #5 on: 31 December 2010, 16:42:00 »
You have to pinch the caps, they are a bit like a child proof bottle if you get my drift ;)
Re: Glow plugs
« Reply #6 on: 31 December 2010, 16:46:27 »
Be careful when undoing the glow plugs from the head as well, they can snap :o
Welung666
Re: Glow plugs
« Reply #7 on: 31 December 2010, 16:47:31 »
Oh it's that type! Same as the the later Zaffy's. I can never get those off ;D ;D
stoxman
Re: Glow plugs
« Reply #8 on: 31 December 2010, 17:02:26 »
Thank you people. I shall make another effort to remove them tomorrow. I dont like the prospect of them snapping. I am guessing this will be the first time they have been removed since new,  104K ago.......
Re: Glow plugs
« Reply #9 on: 31 December 2010, 17:12:17 »
Last set I did were on a 120,000 miler and they came out ok ;)
JasonH
Re: Glow plugs
« Reply #10 on: 31 December 2010, 21:34:35 »
Use plenty of penetrating oil (proper stuff not WD40) ideally change the plugs on a hot engine.
The glow plugs shear in half at about 35Nm so to play it safe take them out with a torque wrench set to less than this.
If the caps are how I think they are there are some horizontal marks for your fingers. Squeeze firmly between finger and thumb and off comes the cap. Think of it like a clothes peg. The plugs have a huge ring round them that the cap clips onto.
Graceland
  • Wakefield
Re: Glow plugs
« Reply #11 on: 01 January 2011, 20:06:58 »
Just done a set on my 165k DTi and they came out alright :)
New set in and pushed the leads firmly home and the car starts first time now as opposed to 2 mins of cranking 8-)
