Author Topic: head gasket  (Read 3890 times)
sotmh
  • london
Re: head gasket
« Reply #15 on: 28 December 2010, 21:35:49 »
can't agree more with skyblue. ;D ;D :y :y
I have been looking at getting another meg (seen 2 possibilities) as I have had the same problem (loads of white smoke but was told by my mechanic head needed recon not just simple gasket change).  I have sourced engineer to do do recon for £160 (can anyone give opinion as to reasonableness) and I will do job myself (dismantle and reassembly etc) plus some other bits and bobs ::) ::) ::)
All this is proviso I am unsuccesfull in obtaining either of the two seen which are cheaper than carrying out job on current. ::)
My current meg is fairly old (R reg 2.0 )
Welung666
Re: head gasket
« Reply #16 on: 28 December 2010, 21:43:19 »
£160 is an average price for a head re-con. But bear in mind this is just the re-con and doesn't cover removal or refitting. You will need a new head gasket set, new head bolts, new cam sprocket bolts and the appropriate torque settings and knowledge to refit the head. The quoted price is also dependant on the condition of the head being re-con'd, if there is a crack or corrosion then the price will go up.
freecall666
  • looking over your shoulder
    • 2.0l sweat tank on wheels
Re: head gasket
« Reply #17 on: 28 December 2010, 21:54:24 »
£290 for one saw other day from an 06, my self if you wont a recon, doit your self, get to know your engine. :y :y
Omega engines only made until 2003 ::)
may not be off an omega. could be vectra etc just says vauxhall 2.2 06 plate.
Solar charger fitted.
If not Broke dont fix it..
CaptainZok
  • Bolton
  • Victim of Cyberbullying.
    • 3.2 MV6 Estate
Re: head gasket
« Reply #18 on: 28 December 2010, 22:05:18 »
It might be rusty. ;D
TuBy's new whipping boy.
sotmh
  • london
Re: head gasket
« Reply #19 on: 28 December 2010, 22:12:41 »
yep, price is just to recon its head.
when I last visited Halfords, they did a gasket headset for appx £54.  Vauxparts £30 - £40
Although, I have never tackled a job this big, i am looking to do that to obviously keep cost down.  I have been quoted a price to do job privately which is far cheaper than a garage price  but I still would want to avoid that if possible although I'm not avderse to remunerate.
I have been sourcing price for correct tools to do job (machine mart for crank and cam locking tools etc).
There are other jobs and parts needing changing which is pushing up price, but as it is said it's good to get to know your engine, and thats the kind of thing I like but if it is not feasible then will go the scrapping route although painful. :( :(
Welung666
Re: head gasket
« Reply #20 on: 29 December 2010, 01:28:54 »
Would your car make it up to me? I'd do you the same deal as Shane :y
Welung666
Re: head gasket
« Reply #21 on: 02 January 2011, 20:33:21 »
just started up and the smoke that came out ... you couldnt see the end of the drive.. the header tank emptied into the engine, the oil is just thick sludge, so i would say the gasket has gone.. i dont have the money to repair so was thinking of scrapping.
Well, had a fun day with Shane. HG definately gone, coolant system was empty, oil had doubled in quantity and was the colour of a strong latte  :o
So off came it's head, HG was trashed, cheapo HG as well and it didn't look like it had been fitted properly hence the failure. Anyway, 5 hours later (including many, many tea breaks and a bacon barm or two) she was running sweet as a nut. Only used cheapo oil and coolant this time as it'll need changing in a couple of hundred miles to finish flushing the system out.
Still it was a good day and an absolute pleasure to meet Shane and Mrs 1000 :y
« Last Edit: 02 January 2011, 20:34:08 by Welung666 »
Danny
  • Wigan, Greater Manchester
Re: head gasket
« Reply #22 on: 02 January 2011, 20:38:32 »
.... and an omega kept from the gates of metal heaven
skyblue
  • Bracknell
Re: head gasket
« Reply #23 on: 02 January 2011, 20:44:11 »
We need to take our hats off to you  Mr .Welung... Well done for keeping another one on the road and the Palace wil be informed of services rendered to such fine motors.... knight hood in the post  I think  ;) ;D ;D ;D
