Author Topic: been reading the thread on pressure testing  (Read 1092 times)
griff2494
  • fallingbostal,germany
« on: 02 January 2011, 22:11:02 »
hi all AGAIN
to came a cap that it shows you on the preasure test thread
is there any other cars that have the same header tank cap as the omega???
only asking as i no theres no omega's in the local german scrap yard
cheers
griff
  • Auckland
    • Mazda MPV
Re: been reading the thread on pressure testing
« Reply #1 on: 02 January 2011, 22:18:45 »
My Carlton and Astras all had the same thread. (I'm guessing that any 1990's Vauxhall cap will fit)
I used an old Carlton cap that had a level sensor. I cut off the level sensor and fitted a schraeder valve in the hole.
« Reply #2 on: 02 January 2011, 23:18:30 »
Just blow into the coolant bottle if your desperate, or a motor bike brake master cylinder cap? It really doesn't need much pressure.
« Last Edit: 02 January 2011, 23:19:35 by chrisgixer »
skyblue
  • Bracknell
« Reply #3 on: 02 January 2011, 23:31:15 »
What happens if you do this then  :-? :-? :-? :-? :-?
« Reply #4 on: 03 January 2011, 00:56:43 »
well yes alright, you have to seal your mouth/cheaks round the the bottle opening first. THEN blow. (sigh) wont taste nice, but i did say if desperate.
« Reply #5 on: 03 January 2011, 00:58:05 »
Yep, and remember... Don't exceed 1 BAR. ;D
« Reply #6 on: 03 January 2011, 01:07:55 »
i used a presta valve in my bike brake master cylinder cap, can blow into that as well, doesnt need an air line even. Seemples.
should add though, that bike master cylinder cap will need something in the lid to make a seal.
Page created in 0.013 seconds with 14 queries.
