Pages: 1 [2] 3  All   Go Down
Author Topic: Jobs and problems  (Read 4983 times)
Welung666
Re: Jobs and problems
« Reply #15 on: 01 January 2011, 15:54:13 »
That is a Tomic part number. Manufactured in Poland. It'll last but nowhere near as long as a genuine gasket. No need to change the head gasket. You need the black sealant though to seal the corners of the half moons and front riser corners.
cube
  • Leeds
« Reply #16 on: 01 January 2011, 15:57:29 »
Thanks for your advice and offer mate  :) i appreciate it.
I've just found the link on how to, so'll have a go tomoz since the in laws are coming round   :o :(, good excuse to get out of the house  ;D
2.2 petrol GLS estate
Welung666
« Reply #17 on: 01 January 2011, 15:57:58 »
Just to add... did it come with the O rings as well? If not you'll need to get them as well. Only tighten the cover down to 8nm when refitting as they will continue to leak if you over tighten them :y
cube
  • Leeds
« Reply #18 on: 01 January 2011, 16:04:52 »
Yep came complete with the o rings, you've just reminded me i need to treat myself to a small torque wrench, a late xmas to myself  ;)
lol lol lol
Thanks again  :y
Kneepad
  • West Scotland
« Reply #19 on: 01 January 2011, 16:42:21 »
While you're in there check your HBV, most likely source of your coolant leak.   :y
cube
  • Leeds
« Reply #20 on: 01 January 2011, 16:50:50 »
I've found the hbv link, reading actually lol, am i looking for leaks at this stage or looking at replacement ???
Kneepad
  • West Scotland
« Reply #21 on: 01 January 2011, 16:59:30 »
Looking at your first picture it appears to be coolant dripping off the coil packs.
Primary suspect HBV. Replacement is the only option. Unless you can see anything else i.e. split or loose hoses.
cube
  • Leeds
« Reply #22 on: 01 January 2011, 17:01:06 »
Its oil dripping mate on the coil pack
scalli
« Reply #23 on: 02 January 2011, 12:48:35 »
Well I have just had a look at this for cube and there is a lot of pressure in the cooling system and a distinct smell of exhaust fumes in the header tank, so unless these engines have an egr cooler which I dont think they do I am putting my money on it being the head gasket. Just need to find somewhere near Bradford to get it skimmed
cube
  • Leeds
« Reply #24 on: 02 January 2011, 17:57:58 »
bump  :)
  • Auckland
    • Mazda MPV
« Reply #25 on: 02 January 2011, 18:21:43 »
Pressurising of the cooling system (particularly before the engine is hot) may be caused by a failing head gasket.
Have you done a compression test? If the readings are still normal  then I would want to get the head off and inspect it for damage before deciding it needed a skim.
scalli
« Reply #26 on: 02 January 2011, 18:27:49 »
Haven't done a compression test, but then again you can often get a good reading even with a failing gasket. From the amount of bubbling in the header tank I am guessing it has blown between the fire ring of one pot and a water gallery
« Reply #27 on: 02 January 2011, 18:35:01 »
4-pot tends to go @ waterjacket on #4 cylinder
  • Auckland
    • Mazda MPV
« Reply #28 on: 02 January 2011, 19:28:25 »
I am guessing you are right :( (you didn't mention the bubbles)
scalli
« Reply #29 on: 02 January 2011, 21:47:55 »
RobG I am guessing you are right, just found a picture of the headgasket and it looks like there is a water channel very close to number 4 pot. With it being that close I think a skim is in order as a couple of thou distortion would lead to it going again
Pages: 1 [2] 3  All   Go Up
