Author Topic: Will not start when warm  (Read 968 times)
ABH
  • West Yorkshire (BD20)
« on: 05 January 2011, 14:56:17 »
2.6 2002 Omega auto
After a run and engine is wtill warm car will not start
When everthing is cold restarts OK
Graceland
  • Wakefield
Re: Will not start when warm
« Reply #1 on: 05 January 2011, 14:59:02 »
Possibly cam sensor?
Have you had the codes read?
Where in West Yorkshire are you, I have a code reader if your car has the OBD socket in the fusebox under the steering column :)
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
« Reply #2 on: 05 January 2011, 15:22:14 »
my money is on a knackered crank sensor,do the pedal trick to get the fault codes
http://www.omegaowners.com/forum/YaBB.pl?num=1189022687
other rides
mrgreen
  • Salzburg/austria
    • 2000 2.2 petrol estate
« Reply #3 on: 05 January 2011, 16:21:06 »
could well be a fault with the crank sensor as when hot the wires are hot as they are routed near the exhaust and a breakdown in these may well be the problem
Warning: Dates in Calendar are closer than they appear.
