Author Topic: coolant change  (Read 940 times)
mahony
  • london
    • omega elite 3.0
coolant change
« on: 06 January 2011, 21:47:03 »
I am going to do a coolant change in the next few weeks and came across a article which seemed a good way to do it but im not entirley sure,the guy concerned did it with a hose running in the expansion tank with the engine running and the radiator plug/tap undone,this way apparently the whole cooling system gets flushed including the block,any thoughts  :question
hotel21
  • The Kingdom of Fife
Re: coolant change
« Reply #1 on: 06 January 2011, 21:51:33 »
I have certainly used that method.  Key thing is to ensure more water goes in than comes out!   ;)
Broomies Mate
  • Bristol, UK
    • Stuff!
Re: coolant change
« Reply #2 on: 06 January 2011, 21:51:37 »
http://www.omegaowners.com/forum/YaBB.pl?num=1167917774
This is for the 2.2
There is additional information for the V6 below (post 3 IIRC).
Edited to add:  I use a hosepipe, as I'm both lazy and impatient.  Just make sure the hose is running at a good enough rate to keep sufficient water in the expansion bottle.
« Last Edit: 06 January 2011, 21:54:12 by Broomies_Mate »
Abiton
Re: coolant change
« Reply #3 on: 06 January 2011, 21:58:44 »
Thing is though, that cold water from the hosepipe will cause the thermostat to be closed, so no flow out of the top hose into the rad.
You'll actually end up with a flow backwards through the bottom hose towards the radiator drain.  The upper parts of the radiator aren't going to see any flow I wouldn't think.  Easy enough to flush that separately though, I guess.  :-/
Edit: actually isn't it just going to go from expansion tank, backwards through bottom hose and out of the rad drain, not necessarily getting round the engine much at all?  :-/
« Last Edit: 06 January 2011, 22:01:54 by Abiton »
