Author Topic: Auto gearbox limp mode, not bc the selector switch  (Read 11592 times)
Remo
  • Oslo, Norway
« on: 22 December 2010, 22:37:54 »
Hello dear forum members and greetings from Norway where its 20 degrees below zero!
I have had a lot of use of this forum as a "passive" member, which have solved several problems I've had with my Omega.
Now, however, I have a problem where I've come to a dead end after reading the forum all evening and spending the last week trying to fix the car. I hope with all my heart that some of you with all your knowledge could shed some light on how to proceed to solve the problem.
This is the case:
The car is a 1996 Omega Estate 2,5 Auto. About a month ago I replaced the AR25 gearbox with an AR35 gearbox, from a newer donor car. After the replacement, the car had new life to it, it ran better and geared a lot smoother.
This past week the gearbox suddenly went into limp mode (stuck in third gear while in drive), with no warning light or anything. I can gear manually to 1st and 2nd gear but in 'Drive' its always stuck in third gear.
To solve the problem, I started with thoroughly cleaning all the contacts on the gearbox (I have just had the entire underside of the car sprayed with oil to stop rust, and there's been a lot of snow) so I thought there was a bad connection. This didn't help.
After reading more on this forum, my guess was the selector switch. The selector switch looked really bad inside so I decided to replace it with the selector switch from the old AR25-gearbox which used to work nicely and also looked nice inside. This didn't help either..
I have no problems with the LED's in the selector inside the car, they all work like they should.
I also have a cheap "tech2" diagnostic tool, "My Naff Code Reader"/Lonelec. When I first tried, I managed to connect to the gear box and there was a lot of error codes (unfortunately I didn't write them down. I cleared all the error codes, but one remained: "Power relay voltage low".
After that, I haven't been able to connect to the gearbox with the diagnostic tool. Today, I went to a friend of a friend that works in an Opel-dealer, and he tried to connect with both TECH2 and TECH1 but he was also unable to connect to the gearbox.
So now I'm pretty clueless where to look next. I don't have a clue where the relay's are, and the Opel-guy was too busy to provide me with any more assistance or wiring diagrams.
Does anybody have any tip on what to check for? I feel a bit desperate right now, I spent so many hours upgrading the car and now this happens.
Thank you for reading and I'm very thankful for every tip!
Re: Auto gearbox limp mode, not bc the selector switch
« Reply #1 on: 23 December 2010, 00:09:09 »
Maybe someone with tis can help. Not a snow mode issue I guess, sounds like your beyond the simpler causes.
Remo
  • Oslo, Norway
« Reply #2 on: 23 December 2010, 09:43:26 »
Yes TIS could probably be useful.
Oh, and by the way, the gearbox oil and filter has been changed and the level seems fine.
Also, the car ALWAYS starts, so I don't think it is the cam shaft sensor. The cheap code reader doesn't show any error codes on the engine either..
Any suggestions will be deeply appreiciated!
Kneepad
  • West Scotland
« Reply #3 on: 23 December 2010, 12:15:18 »
My first thoughts also. Snow button powered on.
« Reply #4 on: 23 December 2010, 12:17:24 »
Def worth checking.
Remo
  • Oslo, Norway
« Reply #5 on: 23 December 2010, 12:20:38 »
Thanks guys.
So you mean that the snow mode button has jammed? The button doesn't light up, but I can try pressing it to see if that changes anything.
Perhaps disconnecting the whole button?
I'll run down to the car to have a quick look right away..
Remo
  • Oslo, Norway
« Reply #6 on: 23 December 2010, 12:27:42 »
Went down to the parking garage here at work and put the car in drive. Pressed the snow mode button several times but the car still started in 3rd gear and sport function wouldn't work.
Didn't try to disconnect the whole thing, should I perhaps try that? Wierd that the diagnostic tools (both mine and at the dealer) can't connect to the gearbox?
Thanks again!
« Last Edit: 23 December 2010, 12:34:37 by Remo »
Remo
  • Oslo, Norway
« Reply #7 on: 23 December 2010, 12:50:59 »
After reading more around, I think I should mention that I had a xenon bulb blown last week and the gearbox problem appeared right after I changed the bulb. Should obvioulsly have no connection to the gearbox problem, but I just wanted to mention it.
Have checked the two gearbox fuses over the footwell and they are fine. However, perhaps I should check ALL fuses.
sandune
  • Essex Southend
    • 2.6 Omega Auto
« Reply #8 on: 23 December 2010, 13:00:32 »
Have you checked the selector contact switch? Maybe on refitting the new gear -box the alighnment is slightly off.
Remo
  • Oslo, Norway
« Reply #9 on: 23 December 2010, 13:03:14 »
Yes I have changed the selector switch. The allignment should be good. Also, the LED's in the gear selector in the car are fine.
This drives me mad, definately ruins my Christmas.. Thanks for all your help
Remo
  • Oslo, Norway
« Reply #10 on: 24 December 2010, 08:40:00 »
I'm just about to order a new gearbox ECU. Pretty expensive, but it's cheaper than leaving the car with the dealer (£150 pr hour).
Any last ideas before I place the order?
Thanks,
PDK1953
  • Maidstone, Kent
    • 2.2 cdxi estate
« Reply #11 on: 24 December 2010, 09:14:40 »
I had a similar problem with my 1999 2.2 petrol estate recently. Gearbox kept going into limp home mode, so many error codes on reader was almost impossible to diagnose reason. It appears to me that the gearbox protection system is so sensitive that any small error switches it into limp home mode.... great in some respects but a nightmare to find the cause  ::)... like you i read the forum threads in detail, created my own thread, changed the selector switch, no effect...the cam sensor, no effect ...and finally the throttle potentiometer in the foot well, and success!!!  ;D.............. I'm not saying yours is the potentiometer, but if you can pick up a recycle one it might be worth a try ............ (a new one is about £150 !!!!)
Remo
  • Oslo, Norway
« Reply #12 on: 24 December 2010, 09:20:54 »
Thanks a lot! I'll definately look in to that. Yeah, looks like its really sensitive.
I have a friend with the same car, maybe I can talk him into "borrowing" the sensor to me for testing purposes.
I'll some time reading about this throttle potentiometer now.
Remo
  • Oslo, Norway
« Reply #13 on: 24 December 2010, 09:29:41 »
Should I have throttle problems if this is the cause of my limp mode problem? The throttle response is normal and the engine revs up like it should
« Reply #14 on: 24 December 2010, 11:39:05 »
Borrowing parts from another known good, is your best bet. Very handy actually. I suppose your first task is to repair communication to the box ecu. If a reader can't see it then maybe the box can't either, hence limp mode.
Theory behind snow mode error is that that function uses 3rd gear for gentle pull away in snow, which is the same as limp mode using third. Thing is pressing sport mode should over ride it, snow mode button is not lit at the time, and bothe sport and snow modes are unresponsive. Gear selector lights are correct. So it's in limp mode it seems to me.
Further diagnosis is difficult tbh, you need one of the admins on here with tech 2 experience. Markdtm, TheBoy, or Kevin Wood. Sugest a pm to the nearest one to you with a link to this thread.
« Last Edit: 24 December 2010, 11:41:49 by chrisgixer »
Pages: [1] 2 3 4  All   Go Up
Page created in 0.037 seconds with 16 queries.
