Author Topic: is there a guide?  (Read 1313 times)
griff2494
  • fallingbostal,germany
is there a guide?
« on: 07 January 2011, 11:00:24 »
hi all
im sure ive seen one but cant seem to find one :-(
im after a step by step guide on how to change the head gasket on my 2002 2.2 16v
cheers
griff
Welung666
Re: is there a guide?
« Reply #1 on: 07 January 2011, 11:04:18 »
There isn't one yet. I've got one to do in a couple of weeks though so was intending doing one. Do you want talking through it?
griff2494
« Reply #2 on: 07 January 2011, 11:09:07 »
hi there
thanks for the reply mate :-)
that would be brill if you could
cheers
griff
Welung666
« Reply #3 on: 07 January 2011, 11:15:40 »
No problem, I'll type one up later on today and post it in the test section :y
When are you doing it?
« Last Edit: 07 January 2011, 11:15:56 by Welung666 »
griff2494
« Reply #4 on: 07 January 2011, 11:25:07 »
nice one cheers mate :-)
hopefully im going to start it today ,still waiting for the postman to bring the cam locking tool (should be today)
and the hg and bolts
but i was thinking i could remove everything else i can before the cams to when it arrives im already to crack straight on
i assume if i take manifold etc off,and line up the crank to its marker ? (i assume theres a marker on the crank pullie/casing)
then it will just be waiting for the postman lol
i have a valve compresser ,so do you think once head off i may as well do the oil steam seals,clean vaulves etc?
« Reply #5 on: 07 January 2011, 11:28:13 »
i have a valve compresser ,so do you think once head off i may as well do the oil stem seals, clean valves etc?
Every time IMO  :y
griff2494
« Reply #6 on: 07 January 2011, 11:35:27 »
nice one i will make sure i  do there then,i assume i just need to grind the valves back in like normal?
any thing else while the heads off ?
