Author Topic: heaters not hot  (Read 1398 times)
dpk76
heaters not hot
« on: 16 December 2010, 16:27:34 »
hi all,i have a 2001 3.0 elite.heaters wont blow hot,checked pipes to matrix on hot one cold.flushed matrix still the same.any ideas it could be anything else but matrix?thanks
Re: heaters not hot
« Reply #1 on: 16 December 2010, 16:33:04 »
Remove & plug vac hose on top of HBV and see if you get heat then
dpk76
Re: heaters not hot
« Reply #2 on: 06 January 2011, 17:32:34 »
hi rob ive tried that and still same.also tried flushing matrix out.wondering possible air lock?just trying things before i go and try new matrix
Welung666
Re: heaters not hot
« Reply #3 on: 06 January 2011, 18:38:11 »
You need to flush the matrix both ways several times. If you connect a piece of hose to each pipe in the engine bay can you blow through one and get air through?
« Last Edit: 06 January 2011, 18:39:14 by Welung666 »
dpk76
Re: heaters not hot
« Reply #4 on: 07 January 2011, 16:49:51 »
both pipes to matrix are hot now but still no heat.took vacum pipe off heater valve still nowt.doesnt seem to be much if any vacum from pipe?
Electraglide
Re: heaters not hot
« Reply #5 on: 08 January 2011, 10:11:25 »
Hi had this problem on a 2lt have you checked your thermastat, if it ok then it could be your water pump. as it was the later on mine .
cndsctl
  • Glasgow
Re: heaters not hot
« Reply #6 on: 08 January 2011, 10:11:59 »
Hi everyone,
I have a similar problem with my car although i am getting hot air in to bak of car just not the front. Anyone know what i should check or do?
dpk76
Re: heaters not hot
« Reply #7 on: 08 January 2011, 14:41:27 »
have not tried thermo yet but car seems to running at about 80 85 which i think may be bit below but i thought it would run less if it was thermo?
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
Re: heaters not hot
« Reply #8 on: 08 January 2011, 18:12:16 »
Unlikely. If this has failed you will overheat big-time. :y
dpk76
Re: heaters not hot
« Reply #9 on: 08 January 2011, 18:14:14 »
someone said possible heater ucu???anyone had this problem before?
