Author Topic: auto problem  (Read 1644 times)
roebuck
  • barnsley
auto problem
« on: 09 January 2011, 09:25:31 »
hi all can sum 1 help i have just got a omega 2.2 auto on a 02 reg when you are driving it goes in to nutral you put it in to 3 and back in to drive and it is ok.or sum times it wont gear up or down or sport buton will not work you turn car off and start it back up and it will be ok :
Re: auto problem
« Reply #1 on: 09 January 2011, 09:33:17 »
fluid level would be my first check  :-/ other than that, I'm not sure
Welung666
Re: auto problem
« Reply #2 on: 09 January 2011, 09:46:20 »
I agree with Andy, first job check the fluid level as per the guide - http://www.omegaowners.com/forum/YaBB.pl?num=1152783586
roebuck
  • barnsley
Re: auto problem
« Reply #3 on: 09 January 2011, 09:51:32 »
thay spot on
Re: auto problem
« Reply #4 on: 09 January 2011, 10:06:12 »
2.2 with auto box, first thoughts, check the atf as said, get the codes read for possible cam sensor issues as thess are a weekness on the 4 pots and known to upset the auto box. Other than that and checking the selector switch it doesnt sound good if its jumping out of gear.
How many miles has it done and was the fluid ever changed?
« Last Edit: 09 January 2011, 10:07:50 by chrisgixer »
roebuck
  • barnsley
Re: auto problem
« Reply #5 on: 09 January 2011, 10:15:06 »
it dont jump out off gear its like its not in gear its got 17700 miles
Re: auto problem
« Reply #6 on: 09 January 2011, 10:22:28 »
Do the selector lights next to the gear lever corespond with the gear lever position?
roebuck
  • barnsley
Re: auto problem
« Reply #7 on: 09 January 2011, 10:28:25 »
yes but now and then there all cum on
Re: auto problem
« Reply #8 on: 09 January 2011, 10:40:41 »
Not sure if that means its its in limp mode? Drives in 3rd gear only, so sport mode wont work, thrn re start it and its fine.
Need to get it on tech 2 preferably, dont bother with a dealer.
Kneepad
  • West Scotland
Re: auto problem
« Reply #9 on: 09 January 2011, 15:48:16 »
It's time to clean the seletor switch.   :y
See here:
http://www.omegaowners.com/forum/YaBB.pl?num=1267956397
