Author Topic: Becoming difficult to start....  (Read 4130 times)
Rockhampton
  • Trecelyn, Gwent
  • Gone!
« on: 06 January 2011, 19:57:07 »
Hi all, not been on for a bit, been off having a baby and moving house  :y
My miggy has been behaving really well over the last few months, however she is sometimes becoming sluggish to start - usually after standing for more than a couple of hours. She does always start, but can take sometimes 5-10 seconds - she's always been a great starter, so really notice it. Sometimes, will start quickly, but others it seems a bit of a struggle. There's plenty of juice in the battery, and always at least 1/4 tank of fuel. No warning lights, and no codes on the pedal trick. Once started, runs fine, no issues at all. Filters all changed (inc. fuel) 12k ago, recent oil change. New 2-4-6 coil pack last year and sealed scuttle, all looks dry in there (symptoms were different then - poor running & eml). I'm going to have a look at the weekend, as I don't want to take it to a garage and have them replace parts until they find the right one at my expense!! >:(
Just wondered if any of you had any pointers or similar experiences - thanks in advance  :y
Previous GM Models include '00 Omega 2.5 CD Auto, '06 Holden Commodore Executive 3.6 Auto, '99 Astra 1.8 CDX Auto, several Astra Diesels.
Welung666
Re: Becoming difficult to start....
« Reply #1 on: 06 January 2011, 20:00:49 »
Any codes stored?
Rockhampton
  • Trecelyn, Gwent
  • Gone!
« Reply #2 on: 06 January 2011, 20:07:47 »
Nothing on the pedal trick - I do it about once a month, and I've had nothing since the misfires on the coil pack over 12 months ago. :y
joshwyatt
  • Oxford
« Reply #3 on: 06 January 2011, 21:23:06 »
My bet would be on the coolant temperature sensor (CTS). I have a 2003 2.6 and I know the CTS has a problem with it. It gives exactly the same symptoms as yours. CTS is cheap, and not a massively hard job to do, although not something I would do myself.
Welung666
« Reply #4 on: 06 January 2011, 21:36:13 »
I'm guessing you mean the 2 wire ECU CTS Josh?
Rockhampton
  • Trecelyn, Gwent
  • Gone!
« Reply #5 on: 06 January 2011, 21:44:09 »
Just been reading on the 'net of the symptoms of a dodgy CTS - it includes fuel economy issues - I've noticed over the last few weeks it's down a couple of MPG on the computer on my regular trips, but was just putting that down to the weather :(
Cheers - anyone know where it is, and what the expected output is if I stick a meter on it?  :y
« Last Edit: 06 January 2011, 21:53:45 by rockhampton »
Welung666
« Reply #6 on: 06 January 2011, 21:55:24 »
There are 2 at the rear on the V in the coolant bridge. A 2 wire for the ECU and a single wire for the dash gauge, hence my question to Josh. No to hard if you take the plenum and skuttle off. I find them easier to get to if I kneel on a cushion placed on top the inlet and looking straight down the back of the engine.
Welung666
« Reply #7 on: 06 January 2011, 21:56:39 »
I've got a few of both (used but working) if you want me to post one of each down to you?
Rockhampton
  • Trecelyn, Gwent
  • Gone!
« Reply #8 on: 06 January 2011, 21:57:16 »
Thanks for that - so I guess that I would only need to replace the two wire one?? :y
Welung666
« Reply #9 on: 06 January 2011, 21:58:33 »
99% yes, but as before I can post you both just to be sure :y
« Reply #10 on: 06 January 2011, 22:10:43 »
I have noticed similar problems on my 2.2 since it had the Head Gasket done, and notice a fall in mpg, though I accept that this will not be helped by the weight I have in the boot to help in the snow........
Till I read this I was thinking Lazy Starter, and also intended to check battery connections both tight; I have not carried out any investigations yet.
Rockhampton
  • Trecelyn, Gwent
  • Gone!
« Reply #11 on: 06 January 2011, 22:19:24 »
Cheers - sending PM  :y
Vamps - I'll let you know how I get on  :y
« Last Edit: 06 January 2011, 22:23:02 by rockhampton »
Rockhampton
  • Trecelyn, Gwent
  • Gone!
« Reply #12 on: 06 January 2011, 22:23:27 »
I'll get the camera out when I do it  :y
Welung666
« Reply #13 on: 06 January 2011, 22:25:21 »
It'll be easier for you Mike if it is the CTS. Same applies though, skuttle off and get a cushion up on top and work downwards :y
« Reply #14 on: 06 January 2011, 22:39:56 »
Is this the potential problem then? and is this something the garage did not do correctly when fixing the car, also have low washer fluid alert all the time as well, fine before it went in  ::) A trusted local guy but given the size of the bill, if he is at fault I want him to sort...
