Author Topic: Please tell me I am missing something obvious  (Read 1570 times)
Malcolm_D
  • York
  • It shines!
« on: 14 January 2011, 19:31:19 »
2.5 V6 98 plate. Big misfire, water in plugs 4 & 6, removed plugs and leads cleaned, dried and refitted, now it refuses to start. Plugs, leads and coil pack were replaced last year. Turns over fine, spark evident as well as petrol, replaced crank sensor - no joy. What is going on? Have raised this issue already and tried everything suggested but I must be missing something basic. Even with the misfire it would start and run on 4 cylinders, not now.  :(
alank46
  • South Devon
    • 3L Elite Estate 1996
Re: Please tell me I am missing something obvious
« Reply #1 on: 14 January 2011, 19:40:33 »
Plug leads on wrong plugs?
« Reply #2 on: 14 January 2011, 20:00:41 »
Or just a loose couple but does sound possible
« Reply #3 on: 14 January 2011, 20:42:45 »
Daft question I know, but you DID remove ALL the water from the plug orifices BEFORE removing the plugs didn't you? :-/
Raymienets
  • Glasgow
    • 2.2 cd & 2.6 LPG
« Reply #4 on: 14 January 2011, 20:57:46 »
The tip I was told to do was to remove all the spark plugs get someone to look in engine bay. turn the car over and see if any water comes out the spark plug holes. When I did mine 4 was like a fountain.  :'( :'(
« Last Edit: 14 January 2011, 20:58:26 by Raymienets »
Malcolm_D
  • York
  • It shines!
« Reply #5 on: 14 January 2011, 22:42:26 »
Will check tomorrow, SWMBO is going shopping, my orders are 'get it sorted'!  :o
Plugs leads are numbered both ends, all water was gone from the plug wells, have checked as many connections as possible but as said will check all again. Thanks for the responses.  :y
Welung666
« Reply #6 on: 14 January 2011, 22:44:43 »
Do a paperclip test (see the link at the bottom of my post) and post back the results.
Malcolm_D
  • York
  • It shines!
« Reply #7 on: 14 January 2011, 22:46:40 »
Will repeat test tomorrow but when I did it a short while ago all I got was a code for the oxygen sensor and the engine not running.  :-/
Welung666
« Reply #8 on: 14 January 2011, 22:47:58 »
It may have stored something else, just in case really as you may have disturbed something while in there :y
Malcolm_D
  • York
  • It shines!
« Reply #9 on: 14 January 2011, 22:50:33 »
Always worth another look, hope it is not raining tomorrow!  :y
Malcolm_D
  • York
  • It shines!
« Reply #10 on: 15 January 2011, 18:10:09 »
Fixed it  :D :D :D :D :D
Coil pack, which was new last year, was the problem, put a new one on and the beast started first time. I am one happy bunny!  ;D ;D
Tried it with the new pack sat on the plenum so now all I have to do is fit it properly and off we go.
Thanks to all the oofers who helped with their suggestions.  :y
