Author Topic: Timing on mv6  (Read 1857 times)
unlucky mark mv6
  • tipton,west mids
Timing on mv6
« on: 12 January 2011, 21:56:00 »
Is there anyway to tell if the timing is out on a 3.2 without stripping it?,or what else could be the cause of high fuel consumption?. :-/
Welung666
Re: Timing on mv6
« Reply #1 on: 12 January 2011, 21:58:56 »
It can sometimes be seen on live data dependant on how far out and where. Who did the belt last time? PM if you don't want it public ;)
« Last Edit: 12 January 2011, 21:59:17 by Welung666 »
unlucky mark mv6
  • tipton,west mids
Re: Timing on mv6
« Reply #2 on: 13 January 2011, 18:12:57 »
Pretty sure it was vx dealer lee,as everything in the history relates to anyway.
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
Re: Timing on mv6
« Reply #3 on: 13 January 2011, 18:40:25 »
If the timing has being done by a dealer from my experience 8 times out of 10  it will be out.  :(
Re: Timing on mv6
« Reply #4 on: 13 January 2011, 19:50:01 »
Multi rams working? Pedal tricked for codes? And all that first?
unlucky mark mv6
  • tipton,west mids
Re: Timing on mv6
« Reply #5 on: 14 January 2011, 00:02:57 »
I know what you mean daz,cant even trust a main dealer today,and yes chris,i think its a good idea to try for any codes first.Ill try with my reader tomoz. :y
unlucky mark mv6
  • tipton,west mids
Re: Timing on mv6
« Reply #6 on: 14 January 2011, 00:04:13 »
How do i know if the multi rams are working? :-/
Re: Timing on mv6
« Reply #7 on: 14 January 2011, 10:54:36 »
Does this help ??
http://www.omegaowners.com/forum/YaBB.pl?num=1153840176
Re: Timing on mv6
« Reply #8 on: 14 January 2011, 11:22:59 »
your idle will be rough and miss some beats.. and the power will be down..
Re: Timing on mv6
« Reply #9 on: 14 January 2011, 11:43:50 »
Either via tech2, or a good blip of the throttle and watch them actuate, so on the 3.2 an assistant will be needed, throttle cable cars can no blipped from the engine bay but not drive by wire.
Although violent blipping of the throttle may not be such a good idea if the cam belt is suspect for obvious reasons. So up to you. Maybe a thorough inspection of vac pipes and electrical connectors instead? :-/
Re: Timing on mv6
« Reply #10 on: 14 January 2011, 16:15:25 »
imo get it checked by a mobile mechanics.. no need to take extra risks..
Welung666
Re: Timing on mv6
« Reply #11 on: 14 January 2011, 21:10:06 »
Mark, if you're not busy Sunday pop over and I'll check the live data etc., and if we can't see anything we'll have the cover off ad check the timing marks :y
unlucky mark mv6
  • tipton,west mids
Re: Timing on mv6
« Reply #12 on: 15 January 2011, 22:09:35 »
Thanks mate,i might just do that :y
