Author Topic: plastic sill covers  (Read 1230 times)
fiend61
  • york
  • each to their own
    • 2.5cdx 3.0mv6 3.2vec c
plastic sill covers
« on: 15 January 2011, 15:10:24 »
hi all
can anyone tell me if the black plastic sill covers on a mfl are removable ?  if so how  :question this goes for the facelift ones aswell are they removable the same way as the mfl
tia
Varche
  • middle of Andalucia
    • Golf Estate
Re: plastic sill covers
« Reply #1 on: 15 January 2011, 15:17:57 »
I can't tell you how they come off but they will. On one of my cars the rear end cover (near back wheel) came off. I have re attached it with self tappers.
Inside you could see the clips that hold it on.
Welung666
« Reply #2 on: 15 January 2011, 18:49:49 »
Push pins along the underside, end caps off (self tappers) and the covers pull out slightly at the bottom then pop off upwards :y
fiend61
  • york
  • each to their own
« Reply #3 on: 15 January 2011, 20:07:01 »
cheers lee i take it the facelift are the same ? will facelift ones fit mfl ? have you got any z147 ?  ;)
« Reply #4 on: 15 January 2011, 20:18:24 »
cheers lee i take it the facelift are the same ? will facelift ones fit mfl ? have you got any z147 ;)
F/L 157`s here and you wouldn`t even know the difference 8-)
fiend61
  • york
  • each to their own
« Reply #5 on: 15 January 2011, 20:19:44 »
pm on way rob  :y
« Reply #6 on: 16 January 2011, 09:58:58 »
The fixing underneath is a press on stud, gently prize them off without damage as they are needed to refit obviously. Then with push stud fixins and the end caps removed they just pull off the clips. Look out for the centre dowls of the push spin fixings once removed, they fall into the side skirt.
fiend61
  • york
  • each to their own
« Reply #7 on: 16 January 2011, 15:01:06 »
cheers chris  :y
