Author Topic: Throttle pedal ...........  (Read 815 times)
I_want_an_Omega
« on: 16 January 2011, 15:29:03 »
I've not used my Mig for some months, but took her out for a good spin today.
However, I noticed that the accellerator pedal has a huge amount of play before anything happens - like about an inch or more. Also, kickdown don't work - which I'd thought was the switch.
before I go to the hassle/cost of replacing the cable/switch assembly, is there anything else that it could be?
Thanks - Rob
Re: Throttle pedal ...........
« Reply #1 on: 16 January 2011, 15:35:06 »
Check cable for slack, if so adjust it by the throttle butterflys by removing the retaining clip by the mounting clamp, pull the cable sheath towards the bulk head until there is no excess slack (you want a small amount) before replacing the clip to maintain the adjustment
I_want_an_Omega
« Reply #2 on: 16 January 2011, 15:39:37 »
Thanks - could that explain why kickdown isn't working?
MutantCav
  • Gainsborough
« Reply #3 on: 16 January 2011, 15:41:00 »
I would agree whole heartedly with RobG...had some play in a past Omega...put up with it for 6 months before investigating...after adjusting the cable correctly I instantly had the full power that the car was meant to have and it responded better too...the little clip had come off
I_want_an_Omega
« Reply #4 on: 16 January 2011, 15:48:06 »
Did your kickdown work before you adjusted the cable?
MutantCav
  • Gainsborough
« Reply #5 on: 16 January 2011, 16:57:04 »
No mate cos the car had lots all its guts as a response and wasnt able to accelerate properly to enable it to cut in...
