Author Topic: 2.5 td wont start code 34/85  (Read 3083 times)
0 Members and 3 Guests are viewing this topic.
gateshead
« on: 16 January 2011, 17:28:58 »
hi guys i have a 1995 2.5td  it wont start it has a flashing orange light on dash looks like a tap i have done a paper clip test it comes back with 34  Injector Timing Out Of Range and 85 Immobiliser Wrong Signal. my car does not have a immobiliser. does any body no were to start with these codes. cheers kevin
charlie
  • sunderland
Re: 2.5 td wont start code 34/85
« Reply #1 on: 16 January 2011, 17:39:51 »
When cranking the engine over does the eml light flash? I believe all omegas have immobilizers
« Last Edit: 16 January 2011, 17:40:59 by charlie »
charlie
  • sunderland
« Reply #2 on: 16 January 2011, 17:47:12 »
when the eml flashes it means that the immobiliser is still engaged,have you being doing anything with the key
gateshead
« Reply #3 on: 16 January 2011, 18:13:07 »
the light flashes constantly when i turn the key to on and it flashes constantly when trying to start. also the abs light flashes when trying to start it as well. i am 100% sure the car has no immobiliser they did not start using them untill 1996 its just a standard key with nothing inside the plastic bit in the key it always comes apart. any ideas ware to start looking for this problem car worked fine parked it up used it again about 2 hours later and car wont start
charlie
  • sunderland
« Reply #4 on: 16 January 2011, 18:27:42 »
94 to 96 cars used the ir system ie key plus seperated fober so still shouldhave an immobiliser  where a car of this age get the signal from,i dont know :y
Kneepad
  • West Scotland
« Reply #5 on: 16 January 2011, 18:42:14 »
Have you a spare key you can try?
hoofing it
« Reply #6 on: 16 January 2011, 19:02:29 »
Are you using the fob key if so open it up carefuly the micro chip might of slipped off its holder :y
gateshead
« Reply #7 on: 16 January 2011, 19:15:38 »
i only have the one key no remote locking. the key is just a normal key with no transponder inside. the plastic bit on the key always comes apart and there is nothing inside. is the injector timming run off the timming chain or the aux belt its maybe sliped a tooth
« Last Edit: 16 January 2011, 19:17:23 by gateshead »
Kneepad
  • West Scotland
« Reply #8 on: 16 January 2011, 19:29:16 »
The ECU uses the input signals from the start of
injection sensor, together with signals from the
crankshaft position sensor.
Start of injection sensor is incorporated in injector #4.
gateshead
« Reply #9 on: 16 January 2011, 19:44:04 »
kneepad thanks for reply but your info is to technical how can i use it to proceed forword
Kneepad
  • West Scotland
« Reply #10 on: 16 January 2011, 20:11:48 »
You could check the wiring at #4 injector or try a new injector.
It could be the crank sensor but your codes point to the immobilser.   :-/
gateshead
« Reply #11 on: 16 January 2011, 20:25:06 »
well its some were to start kneepad i will give it a try tomorrow
Kneepad
  • West Scotland
« Reply #12 on: 16 January 2011, 20:48:17 »
Double check your key. I thought there was no chip in mine until I saw this:
Omegatoy
  • UK
« Reply #13 on: 16 January 2011, 21:18:24 »
if no chip in the key it wont start!! unless a previous owner has taped the chip to the ignition barrel or somewhere close :-[
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
« Reply #14 on: 17 January 2011, 09:30:33 »
Is it possible that the last time this happened the chip fell out?
Page created in 0.028 seconds with 16 queries.
