Author Topic: Code 57 Idle Air Control Voltage Low  (Read 862 times)
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
« on: 18 January 2011, 18:19:13 »
Am I looking in the right place, this is the from the NS middle bit from the penlum back to front before throttle body? or am I totally looking in the wrong place. Guessing no volts going to where it should be.
Thanks Chris.
Re: Code 57 Idle Air Control Voltage Low
« Reply #1 on: 18 January 2011, 18:21:18 »
ICV, passenger side about midway along the side of plenum. Silver cylindrical jobbie
zirk
  • Epping Forest
« Reply #2 on: 18 January 2011, 18:25:57 »
Thanks Rob, thouht Id check before unpluging things that dont need un plugging  :y
See you tomorrow by the way.
