Author Topic: Ignition comes on when Hazard Light is pressed?  (Read 859 times)
marty1981
  • Ramsgate, Kent
« on: 18 January 2011, 16:07:07 »
Hi Guys,
I took the original headunit out of my 2000 Omega.
I had to take off all the wood surround, this all came out fine.
Now I have put it all back when you press the Hazard Light switch the Ignition Comes On (Dash Lights Up)
The Hazard Lights do not come on though. (But they flash when car is locked/unlocked as usual)
When you press it again to switch off, the Ignition Switches off.
This happens without the key in the Ignition.
Any help would be greatly appreciated, i'm really stuck with this one!
Thanks in advance.
marty1981
  • Ramsgate, Kent
Re: Ignition comes on when Hazard Light is pressed?
« Reply #1 on: 18 January 2011, 16:55:00 »
Just done a bit more research on the Net. Realised that I have put the Hazard Light Switch in the wrong way up!
D'oh! :-[
Well, if anyone else makes the same mistake. Thats how you fix it!
Welung666
« Reply #2 on: 18 January 2011, 16:55:21 »
Do the indicators work as they should?
Welung666
« Reply #3 on: 18 January 2011, 16:55:59 »
D'oh! :-[
That's what my question was leading up to ;) ;D
marty1981
  • Ramsgate, Kent
« Reply #4 on: 18 January 2011, 20:18:41 »
lol :) Thanks tho for your help
