Author Topic: Opel vs Vauxhall Omega!  (Read 1228 times)
olzz
« on: 18 January 2011, 21:33:19 »
Hello!
Quick question to the crowd- Can anybody list the techincal differences between the left and right hand steering?
Im driving with Opel omega 2,2 manual, sedan 2001. And few spare parts need replacement- central door lock module, driver side lock mechanism, ac compressor and catalythic converter.  Can these parts from Vauxhall  be fitted to Opel.
I know that front light lenses, internal dashboard and power steering is different is different for Vauxhalls. Anything else?....
Cheers,
Olzz
Re: Opel vs Vauxhall Omega!
« Reply #1 on: 18 January 2011, 22:35:50 »
Hi,
I dont see any obvious reason for the parts you mentioned to be different..(the only exception can be central door lock module , may be) so my answer is yes..
but if you need a complete list of technical differences , I'm not sure even the factories can print them in a minute :-/
« Reply #2 on: 18 January 2011, 23:07:26 »
Hello!
Cheers,
Olzz
Should be all the same. As for the C/L module, get the ID/part number off yours
olzz
« Reply #3 on: 19 January 2011, 06:33:54 »
cem and RobG- thanks for the fast feedback.
I know that the central lock module will be hard nut to crack. Even if the new module will be purchased from the factory, there is some matching required with engine ECU in official service.  I will have to take the risk that the programming works with the Vauxhall door module and  my current Opel.
Anything elso to keep in mind?
Boditza
  • Craiova, Romania
« Reply #4 on: 19 January 2011, 06:44:59 »
you can't use the steerig box from vaux to opel or viceversa.. apart from that its the same
