Author Topic: Front tracking what was WIM value?  (Read 1178 times)
Martin_1962
« on: 17 January 2011, 15:08:26 »
Possible dodgy track rod end so need the toe value if it gets changed during MOT.
Thanks
Martin
Re: Front tracking what was WIM value?
« Reply #1 on: 17 January 2011, 16:14:37 »
Just a little toe in. From memory -10' +/- 10'.
« Reply #2 on: 17 January 2011, 18:19:45 »
Defo minus 0.10 mins, thought it was +- 0.05 mins. But yes close enough.
    • 530D M Sport, 330i Coupe
« Reply #3 on: 17 January 2011, 18:42:00 »
For the small cost difference I would buy the whole track assembly for that side, not just the rod end. I had just the track rod end fitted on one side of the estate and it turned out to be a pig due to a crushed collar.
If you buy the whole assembly (Buypartsby or similar) you can place the new unit next to the old unit and get the initial setup pretty close.
« Last Edit: 17 January 2011, 18:42:25 by VXL_V6 »
Liam
« Reply #4 on: 18 January 2011, 23:04:14 »
Toe-in is positive, so you want 0°05' +/-0°05' either side (or 0°10' +/-0°10' total toe). Was at WIM today.
Martin_1962
« Reply #5 on: 19 January 2011, 11:52:09 »
Passed on it anyway.
Need to replace a rubber sometime.
Trying to avoid a trip to Chesham as I have been twice in the last 2 years
