Author Topic: lpg kit for my 3.2 estate with engine pre-heater  (Read 2719 times)
Cliffo B
  • Leeds West Yorkshire
    • 03 3.2 Elite Estate
« on: 19 January 2011, 13:28:57 »
I'm going to do a lpg conversion on miggy and would be gratefull for advice on what spec kit is best to get for her a 3.2 V6 Omega. I understand from reading info already posted that Stag is the front runner. Also does anyone know if haveing a Kenlowe engine preheater fitted needs any special consideration?  :y
Re: lpg kit for my 3.2 estate with engine pre-heater
« Reply #1 on: 19 January 2011, 16:14:26 »
why has it got a engine pre-heater? Is it really needed in the UK  :-/
Stag kit has been trouble free for most part, lots of miles clocked up without issues. Huge experience of it here too  :y
How exactly is the pre-heater plumbed in?
« Reply #2 on: 19 January 2011, 17:15:42 »
LPG coolant plumbing only really affects the section from rear of block to hbv, ie coolant exit rear of block to vaporiser to hbv. That's it.
Although usually the winter heater on the inside of the drivers wing is removed, as it does bog all anyway, to site the vaporiser instead.
Guessing you'll know more than us about how the pre heater is plumbed in.....?
« Reply #3 on: 19 January 2011, 17:18:50 »
Ps, the 3.2 is far easier to convert due to the lack of emissions gubins and throttle cables of the non DBW cars, so space is a bit more available.
2woody
  • Northumberland
« Reply #4 on: 19 January 2011, 17:23:53 »
pre-heater is great for LPG - it means that you don't need to start on petrol if the coolant is pre-warmed.
« Reply #5 on: 19 January 2011, 17:32:02 »
Yeah, i see why they employed you! I never thought of that at all.
« Last Edit: 19 January 2011, 17:32:43 by chrisgixer »
« Reply #6 on: 19 January 2011, 17:35:05 »
Although I wonder of the stag software allows starting on gas straight off ?
Certainly if warm switch over time can be set to minimum .
« Reply #7 on: 19 January 2011, 18:21:36 »
It will start on petrol and switch over after the timeout. You can start on gas but it's grumpy due the the enrichments required on petrol.
It's really only a matter of finding space to mount the components. No reason why it wouldn't work with a kenlowe as long as coolant flow is strong enough to provide adequate circulation through all the components.
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
« Reply #8 on: 20 January 2011, 00:25:41 »
The Kenlowe pre heaters work well on lpg in the winter and on petrol for that matter, they bring the engine temp up to near normal running temp, hence a saving on petrol cold start ups and allowing the lpg to switch over on drive away. The down side is that the commercial versions run on either 110 or 230 volts so there pretty much home based applications (they have there own internal pump fitted).
There are some 12 volt versions around but cost the earth and mainly designed for Track / Race applications.
Switching lpg to force start up when cold should be done with care, as any miss fire or blow back can cause problems with the Maf / intake sensors.
« Last Edit: 20 January 2011, 00:37:14 by zirk »
Cliffo B
« Reply #9 on: 20 January 2011, 02:45:07 »
Hello,all the preheater heater unit is a 3" wide by 6"high cylinder mounted on the side of the offside suspension turret in the engine bay the heated coolant output from it goes via a 12v auxillary pump mounted on the hose to the upper heater matrix supply on the bulkhead. The return pipe to the cylinder comes from the rear of the engine. I believe it circulates the coolant round the full engine till it reaches 80 degrees, but there are optional heater stat's available and also optional wattage heater eliments. I would think the pump is powerful enough with an impeller that won't restrict coolant supply if it suffers a power loss as obviously it's not powered up when engine is started and running normal. Can I say there are some real advantages and it's been great during the recent cold spell, but I use it all year round mainly because the engine starts are less stressfull to me as theres far less mechanical noise and no fast tickover. I would'nt even consider a diesel without one.So it looks as if it won't interfere with the LPG system could even help it on start up,although I'm takeing on board a petrol start will still apply but could get a quick change over,Ill post up about it when I try it out. :yThanks for your helpfull replies next hurdle is getting a front end kit I believe its called, and sorting the inlet manifold and injectors
« Reply #10 on: 20 January 2011, 13:18:02 »
I think your only challenge will be finding somewhere for the vapouriser to go, as it sounds like you've got the Kenlowe in the preferred spot already. No reason why it couldn't go in the "loop" that feeds the Kenlowe. You will need to take a look round the back of the engine and make sure that that part of the system is fed straight from the coolant bridge and not after the HBV, as the aux. pump normally would be, as the vapouriser would then go cold when the HBV closes.
Cliffo B
« Reply #11 on: 21 January 2011, 00:34:52 »
Thanks Kevin,think I can follow your logic,I will have to make sure this vapouriser is in the same coolant loop as the engine preheater so long as the HBV is not able to close the loop,so I need to trace back where the return pipe to the preheater comes from. Once again thanks for spotting this :y
