Author Topic: Omega 2.5TD (BMW Engine) Sump Removal  (Read 828 times)
Mattie
« on: 22 January 2011, 13:53:18 »
When starting oil light sometimes comes on and there is a knocking noise if I switch off and start again it might clear I might have to do this several times before it clears.  Someone suggested it could be oil pick up in sump.
Anyone had anything similar or any advice.
« Last Edit: 22 January 2011, 14:26:25 by Matt_Ford »
hoofing it
Re: Omega 2.5TD (BMW Engine) Sump Removal
« Reply #1 on: 22 January 2011, 19:06:16 »
Sounds like the oil lifter is blocked.
How often has it been between oil changes/when was the last time the oil was changed.
Seth
  • South Wales Valleys
    • '99 2.5TD GLS Estate
« Reply #2 on: 22 January 2011, 22:02:41 »
One thing's for certain if you do indeed need to remove the sump .......
You'll need to remove the rad and sub-frame to effect this.
"Been there - done that etc!"
 :D
Oh, and if the sub-frame doesn't go back EXACTLY to it's original position afterwards, you really need to have a full WIM set-up too.
 :o
PM me if you need any advice etc!
HTH
« Last Edit: 22 January 2011, 22:03:12 by Reliance505 »
