Author Topic: Ruff Idle  (Read 1424 times)
J18BES
Ruff Idle
« on: 23 January 2011, 21:10:29 »
well ive noticed since had the my megga 2.6 v6 that it abit ruff on tick over now this pic is the car warm and ran after being up motorway
what should it idle at ?
any ideas on what could be?
Re: Ruff Idle
« Reply #1 on: 23 January 2011, 21:12:32 »
looks spot on if the climate is not on....
J18BES
Re: Ruff Idle
« Reply #2 on: 23 January 2011, 21:25:15 »
my climate was running when this was taken.
Re: Ruff Idle
« Reply #3 on: 23 January 2011, 21:28:57 »
But if the outside temperature was reading 5C or under (likely) then the climate will have turned itself off ;) :y
Danny
  • Wigan, Greater Manchester
Re: Ruff Idle
« Reply #4 on: 23 January 2011, 21:29:13 »
check for oil leaks round your rocker covers, could well have a bit of oil leaking into the plugs
like mine ;D
J18BES
Re: Ruff Idle
« Reply #5 on: 23 January 2011, 21:33:03 »
ill have a good look tomorrow and if time ill get the plugs out and check them over. is it easy to get the dis pack out to check if is rusted?
Re: Ruff Idle
« Reply #6 on: 23 January 2011, 22:48:55 »
Pedal trick for missfire codes. Suspect ac pump not actually running, iirc the idle is a fraction higher with ac running and might feel a little smoother, certainly my preface lift did, although it's not so noticeable on the dbw cars ime.
