Author Topic: drivers electric seat  (Read 1098 times)
jimex69
  • glasgow
« on: 24 January 2011, 16:50:40 »
hi all my drivers seat gave up the ghost last night i was hoovering the car went to put the seat back to normal position it went so far and just stopped it sounds as though the motor is still working as the seat will go back then forward so far before it just stops in the manual it says use the crank handle to adjust when the electric part fails only problem i dont have the crank handle anhy ideas what i can use to adjust my seat helpppppp [smiley=angry.gif] [smiley=angry.gif]
Welung666
Re: drivers electric seat
« Reply #1 on: 24 January 2011, 16:52:46 »
Is the seat still moving a little bit or are you just hearing clicking noises?
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
« Reply #2 on: 24 January 2011, 16:57:39 »
if the seat will still move a bit it sounds as though you may have a coin or something stuck in the runners,if you raise the seat as high as it will go have a look for anything jammed in there
other rides
jimex69
  • glasgow
« Reply #3 on: 24 January 2011, 17:00:59 »
hi seat will go all the back will raise up and go down but stops about 4inches from the end of the runner going forward
sport
  • Stoke on Trent
« Reply #4 on: 24 January 2011, 19:37:11 »
My seat done the same on high setting seemes somthing jamed but can not see enything in the way
« Reply #5 on: 24 January 2011, 20:13:31 »
Look down the inside edge beside the seatbelt "stalk" .. there is a small gap where the stalk attaches to the side of the seat.....  a coin will fall through there very easily.. but is a sod to see and a b*****d to get out
This is what 1 euro looks like after it was eventually removed
http://www.omegaowners.com/forum/YaBB.pl?num=1260641299
The removal was done from behind the seat with a long screwdriver poking forward until it moved enough to get one of those 3-pronged flexible pickup thingies onto it from the front.
Only took an hour of faffing and swearing  .. :(
jimex69
  • glasgow
« Reply #6 on: 24 January 2011, 22:33:30 »
thanks for the tips guys as usual the o,o,forum has been brill
Page created in 0.008 seconds with 16 queries.
