Author Topic: Xenon Headlight ECU  (Read 1271 times)
SP_3.2
  • Leicester
    • drives A6 allroad 3.0tdi
Xenon Headlight ECU
« on: 25 January 2011, 09:36:44 »
Now where would one find this bad boy on the car.
Just looking to check the conection
Thanks
Steve :y
Re: Xenon Headlight ECU
« Reply #1 on: 25 January 2011, 10:30:20 »
Up behind the front wheelarch liner on the driver's side, IIRC.
The connections to them can chafe and cause problems.
SP_3.2
  • Leicester
« Reply #2 on: 25 January 2011, 10:48:50 »
Cool , thanks could i get to it from under the car or would i have remove the liner.
« Reply #3 on: 25 January 2011, 11:27:54 »
Should be able to access it by removing fastenings on the front end of the liner, no need to totally remove
SP_3.2
  • Leicester
« Reply #4 on: 25 January 2011, 12:11:14 »
Great thanks :y
Welung666
« Reply #5 on: 25 January 2011, 13:05:09 »
Fairly easy to get to if you take the front drivers side wheel off and the fasteners to the arch liner :y
