Author Topic: 2.5 v6 crankshaft pully  (Read 1088 times)
mowerman
  • bedfordshire
« on: 25 January 2011, 16:43:20 »
while removing the pully i chiped one of the ribbs its only small
will it be ok
are the pullys the same on 3l and 2.5 iv seen one on ebay
markspark
  • Bolton
Re: 2.5 v6 crankshaft pully
« Reply #1 on: 25 January 2011, 16:48:29 »
personally i would change it if its already off the car as it could cause problems with the belt also could be out of balance and cause other problems, not sure if 3.0l is the same i would have thought it would be
mowerman
  • bedfordshire
« Reply #2 on: 25 January 2011, 16:58:13 »
dose anyone have a pully im also looking for a cable tray
the black box were the vacume hozes join the ram piping
mowerman
  • bedfordshire
« Reply #3 on: 25 January 2011, 17:11:03 »
i have finaly got round to changing my cambelt although the car has service book stamps there is no evidence of the belt change at 90,000
im half way through doing i its striped downs cams locked
found 2 markings on cam pullys
rained off now
i went out to buy torx socets for it to find normal one fit
markspark
  • Bolton
« Reply #4 on: 25 January 2011, 17:12:51 »
if you put a wanted ad in the test section on the forum on of the very nice admin may move to the correct section for you im sure someone will have one for you there are a few people greaking these cars now
mowerman
  • bedfordshire
« Reply #5 on: 25 January 2011, 17:18:25 »
because im new i cant use that section
davethediver
  • Blackburn, Lancs.
« Reply #6 on: 25 January 2011, 17:21:48 »
You CAN put an ad in the test section, wanted posts often get moved to the parts section, just don't try and sell anything ;)
P.A. Caron de Beaumarchais
