Pages: 1 [2] 3  All   Go Down
Author Topic: omega 2.2 auto facelift car and spanner light  (Read 3721 times)
alan36
Re: omega 2.2 auto facelift car and spanner light
« Reply #15 on: 25 January 2011, 20:08:49 »
the cam sensor was fitted about a week ago and is from vauxhall so don,t no but i suppose it could be possible
Proz
  • Largoward , Fife , Scotland
    • Omega-less now :-/
« Reply #16 on: 25 January 2011, 20:09:49 »
the crank is aftermarket
Mmmmm ...  ::)
alan36
« Reply #17 on: 25 January 2011, 20:12:31 »
thanks rob i will remove the crap aftermarket clean my original and put that back but as for the gearbox do u think it could be low on fluid
« Reply #18 on: 25 January 2011, 20:13:40 »
Mmmmm ...  ::)
my initial thought too , but I know nothing about 4 pots  :-/
« Last Edit: 25 January 2011, 20:14:46 by Andy_B »
« Reply #19 on: 25 January 2011, 20:13:54 »
Wouldn`t hurt to check the fliud level http://www.omegaowners.com/forum/YaBB.pl?num=1152783586
« Last Edit: 25 January 2011, 20:14:56 by RobG »
Welung666
« Reply #20 on: 25 January 2011, 20:15:18 »
4 pots will run with a broken crank sensor but like a bag of spanners.
« Reply #21 on: 25 January 2011, 20:16:12 »
Mmmmm ...  ::)
You know that they are only two thirds of a proper engine (allegedly) :D
« Reply #22 on: 25 January 2011, 20:18:38 »
is that why it now has a spanner on the dash!  ;D ;D
alan36
« Reply #23 on: 25 January 2011, 20:19:23 »
andy b it was running fine before i did the crank sensor it was changed purely because i couldn,t get rid of the light but i think that could be more to do with the level of fluid in the box or service rather than the crank sensor many thanks for all your help i will change and start again
alan36
« Reply #24 on: 25 January 2011, 20:27:21 »
what can i use to clean the old crank sensor up with
« Reply #25 on: 25 January 2011, 20:34:14 »
I believe you're on a hiding to nothing trying to revive an old crank sensor.  :-/
alan36
« Reply #26 on: 25 January 2011, 20:38:37 »
one of the other guys on here suggested i put it back what do u think if the car was running fine before i put this aftermarket in all that was wrong was the car and spanner light was on so sorry so it could be that it was more gearbox related
« Reply #27 on: 25 January 2011, 20:48:21 »
Before you changed the crank sensor were you getting an 0335 code
alan36
« Reply #28 on: 25 January 2011, 20:49:30 »
rpm signal incorrect, and 2 p1700 codes i do believe
alan36
« Reply #29 on: 25 January 2011, 20:53:20 »
each time we cleared the error codes it would let me do possibly 4 miles the flick the light on then someone suggested it could be the crank sensor after already changing the cam sensor
Pages: 1 [2] 3  All   Go Up
