Author Topic: Oil filter canister. 12mm hex drive?  (Read 1631 times)
V6 CDX-er
  • Sheffield
« on: 26 January 2011, 03:31:56 »
As per the tittle really chaps.
I've managed to cut off the chewed up cap of my oil filter canister, removing the very dirty filter element inside in preperation for converting it to a spin-on oil filter.
Inside, attatching the canister to the block is a hex drive. The biggest hex drive that I have is 10mm, which is too small. So in order that I buy the correct size hex drive tomorrow, I just wanted to confirm what size hex drive I will need.
12mm?
13mm?
14mm?
In advance, many thanks  :y
Cliffo B
  • Leeds West Yorkshire
    • 03 3.2 Elite Estate
Re: Oil filter canister. 12mm hex drive?
« Reply #1 on: 26 January 2011, 10:08:24 »
Its 12mm posted this up not long ago :y
« Reply #2 on: 26 January 2011, 10:24:42 »
I've got one if you can wait until Sunday ;)
Cliffo B
« Reply #3 on: 26 January 2011, 10:34:28 »
Sorry just noticed your converting to a spin on I nicked some of swmbo's cotton wool buds to soak the oil from the threads in the block then used a bud soaked in celly thinners to remove any oil traces, and you then need to use thread locker on the threaded sleeve,hope it goes ok :y
Cliffo B
« Reply #4 on: 26 January 2011, 10:44:22 »
Oh, further thoughts on this I've still got a good lid and bolt but a broken filter body so if yours is ok you could have my lid :y
V6 CDX-er
  • Sheffield
« Reply #5 on: 26 January 2011, 13:22:55 »
Thanks but I'd like to be cracking on with it as soon as.
About the only jobs I can be doing is this, adjusting the handbrake and bleeding the brakes.
The car is starting to do my head in now, so I just want to hurry up, get it sorted and on the road.
V6 CDX-er
  • Sheffield
« Reply #6 on: 26 January 2011, 13:26:23 »
Thanks for the tip above Cliff.
Judging by how tight the canister was and the state of the old filter, I reckon the oil hasn't been changed since the Romans were busy nailing Jesus to some wood  :o which may explain why the canister was so difficult to remove.
Even so, I'd still prefer to use a spin-on filter and already have all the parts needed. Cheers anyway  :y
V6 CDX-er
  • Sheffield
« Reply #7 on: 26 January 2011, 17:30:39 »
And one last quick question....
Once the old canister is removed, there is a large rubber 'O' ring that looks like it fits just inside the lip on the engine block.
Before fitting the new spin-on canister, does this 'O' ring need re-fitting? if so then I guess a new 'O' ring would be a good idea?
Cheers.
V6 CDX-er
  • Sheffield
« Reply #8 on: 27 January 2011, 01:53:24 »
Sorted. Old 'O' ring not needed.
