Author Topic: omega 2.2 auto p1555 fault code help  (Read 1176 times)
alan36
« on: 27 January 2011, 22:04:52 »
i have a p1555 fault code any help would be greatful
Re: omega 2.2 auto p1555 fault code help
« Reply #1 on: 27 January 2011, 22:33:05 »
Thottle position sensor. Normally a strip & clean of throttle body will sort
alan36
« Reply #2 on: 27 January 2011, 22:41:28 »
mant thanks rob sorted the crank sensor that is fine now if successful will it turn the car and spanner light out
« Reply #3 on: 27 January 2011, 22:42:28 »
It did on mine :y
alan36
« Reply #4 on: 27 January 2011, 22:45:01 »
ok m8 many thanks will give that a go tomoz.
davethediver
  • Blackburn, Lancs.
« Reply #5 on: 27 January 2011, 22:45:25 »
Mine too stripped it down good old clean loads of carb cleaner and no light on for the past 20K :y
P.A. Caron de Beaumarchais
« Reply #6 on: 27 January 2011, 22:47:10 »
Don`t forget the tiny pinhole in the body.............while you`re at it you may`s well do the breathers.
alan36
« Reply #7 on: 27 January 2011, 22:47:55 »
tyvm i will defo try that then
